help help guys!!
Old Jun 20, 2006 | 08:48 PM
reggaeboyz's Avatar
help help guys!!
this sound is driving me crazy make me wanna crash the max!...this annoying sound make the max seem like a piece of junk on the streets...its a shaking sound like when the stablizer links bushing are worned but i just changed them so its not them..the sound goes away when i hit the brakes while driving..but comes back when i let go off the brakes..help guys
Old Jun 20, 2006 | 08:53 PM
talisman311's Avatar
you check your brake pads lately? wheel bearings maybe?
Old Jun 21, 2006 | 07:39 AM
reggaeboyz's Avatar
well i just changed the front pads..could the wheel bearing do that?...maybe i gotto check that
Old Jun 21, 2006 | 07:41 AM
f550maranello2's Avatar
werd lift up the front end... lock ur steering wheel and try to move the wheel back and forth... my **** is bad and its loud... and the car shakes also
Old Jun 21, 2006 | 07:46 AM
MadMaxima99's Avatar
have this same probelm on my 1990 olds toronado, the rear brake caliper bracket is worn. When i take off the tires and tap or kick the caliper itself, it makes a rattle. Now i know the max has a simular brake set up. Mine goes away when i step on the brake because its under pressure and grabbing onto the rotor. So it can't rattle, but when i let go the rattle comes back. You might need a new bracket or a couple of loaded calipers if you can't find the bracket seperate.
Old Jun 21, 2006 | 08:08 AM
reggaeboyz's Avatar
madmaxima that maybe the problem because you described it exactly as it is...ill be checking that out and replace the caliper..thanks alot guys
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
