Driver window sticks to inner weather stripping?
My driver side window is driving me crazy!?! when its humid out i go to roll down my window and the door panel weather stripping looking line that holds the glass gets stuck against the window and rolls inside with the glass, making the window get stuck with it!
I have no idea what to do, this is driving me crazy when i cant open the window to pay a toll!!
any thoughts?
any thoughts?
spray the weather stripping where the window is sticking with 4way or some other light spray lube, I use to do auto glass and that would probably be the first thing we would have tried, or maybe use some mothers back to black trim care to see if it would prevent the sticking issue.
Originally Posted by borka
Doh!
Replace what?? The whole door panel???
if you dont have any usefull advise, dont post.
Thanks, ill try to take off the door panel and see if i can just take off that top piece. I thought that the weather strip is part of the door panel...
The reason i posted is because i thought that this would be a common problem with a simple solution from some one who went through this.
no its not common from what ive seen, but i have seen what you are talking about in other cars, i usually just rip it out though but i know many people on here are far less ghetto than me. that piece should not be attached to the door panel, if you pull the door panel off (i never have on the maxima but have done so on plenty of other cars) you should see that it rests inside some kind of groove/notch type thing at the top of the inside door panel. it may have just lost its grip over time and need to be reset, or maybe its melted and warped in shape, the only way to find out for sure is to check
I had that problem after I got my windows tinted. The guy who installed the tint told me to roll the windows all the way down after three days. I ignored him and did it halfway, and it got stuck. Just hold the button to roll it up, then use your finger to pry up (not off) the weather stripping untill the windows goes up. The pushed the stripping flush to the windows. Next, take your hands off and roll down the window all the way. Once its down, make sure that the stripping looks like your other doors. It was an easy fix for me, but yours might just be messed up or something. I had to open my door to talk to the school police officer at the entrance because I couldn't roll down my window, haha. But I fixed it, no problem!
Mar 12, 2020 12:06 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
