more lca removal question
Old Jun 21, 2006 | 06:53 PM
200kMax's Avatar
okay. thanks to the advice i got from all u peeps i was able to get the 19mm nut off the ball joint off w/o having to take apart my axle.
in fact, i got all the bolts off the control arm, but heres my next big problem.
how the heck do u get the ball joint off the control arm?
i tried tapping, i tried the pickle fork. it just wont budge. right now i gave up for the nite, and the lca is hanging on the ball joint stud. (good thing i have new joints w/ the new arm)
pb-blasting didnt do any justice either.
Old Jun 21, 2006 | 09:13 PM
p00tan6's Avatar
i believe they have to be pressed out.
Old Jun 21, 2006 | 09:15 PM
Fr33way™'s Avatar
Wild for Width
I had it pressed out (and new one in) for maybe $15
Old Jun 21, 2006 | 09:16 PM
matty's Avatar
You do need to get them pressed out.
Where do you guys buy ball joints ?? Nissan doesnt sell them seperate. Im guessing ill make some called locally
-matt
Old Jun 21, 2006 | 09:24 PM
killerVQ30DE's Avatar
2nd'd
Old Jun 22, 2006 | 12:43 PM
maximus_96's Avatar
autozone rents out a balljoint press which is basically a glorified c-clamp.
Old Jun 22, 2006 | 01:00 PM
BEJAY1's Avatar
Conecarver
Or kits like these should work too.
Old Jun 22, 2006 | 01:06 PM
JeremysBlkMax97's Avatar
I believe he is referring to how to remove the ball joint from the hole in the steering knuckle. The pickle fork will work. Trust me. Since you are replacing them anyways, just fit it in there snugly and use a mini-sledge type hammer. When I did mine last month I ran into the same problem. The fork will destroy the old ball joint, but that doesn't matter. Just keep hitting it and wiggling it around, eventually the ball joint will pop loose.
Old Jun 22, 2006 | 03:47 PM
maximus_96's Avatar
oh yes, to get the ball joint off the knuckle took me forever. just hammer the fork in as far as you can, then hit the fork and pray you don't accidently scratch up the fender somehow. its a pain because there's not much room to swing the hammer under the fender.
Old Jun 22, 2006 | 04:16 PM
200kMax's Avatar
actually, sorry i was a bit vague. yes, i meant the ball joint from the steering knuckle. well, im an idiot. cause the pickle fork i have is a tie rod separator, which is actually, a tad too small to remove the ball joint. im gonna try to get something bigger, and try again.
thanks guys.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Colossus
Sep 9, 2015 05:46 AM
lowpost99
Sep 8, 2015 05:06 AM
