Installing Stainless Steel Clutch line on 4th Gen.
Old Jun 21, 2006 | 08:15 PM
Zack342's Avatar
I purchased a new stainless steel line a couple weeks ago and I wanted to install it this weekend. Can anyone give me a heads up on what is involved in this install and the difficulty. If anyone has any pics that would be very helpful. thanks in advance.
Old Jun 22, 2006 | 01:09 PM
ThurzNite's Avatar
Install the same order as bleeding: rr, lf, lr, rf. Install the caliper end first. Disconnect old line, plug it (so it doesn't get too messy). Connect the new line. Route the new line following the old one. Disconnect old line from hard brake line on body, connect new one. While you're there, install speedbleeder from oakos.com. Then bleed. Remember to keep the reservoir full.
Before you move the car, spray everything down with a hose asap to wash away the brake fluid.
Jae
Old Jun 22, 2006 | 02:06 PM
Flava_24/7's Avatar
Boosted Panda
Jae
He is not installing SS brake lines, its a clutch line he's installing
Zack342,
Its really easy, the ss line replace both rubber lines, upper and lower.
Just make sure you use a 10mm flare wrench to break loose the OEM line, if not you can very easily strip it.
Old Jun 22, 2006 | 02:41 PM
SPiG's Avatar
SomePsychoGuy
10mm flare wrench is very important. With that you are going to give it a lot of torque to break it from the hard line. You can remove the slave cylinder to make that part easier.
Bleed from the slave cylinder and then the strut tower bleeder.
Old Jun 22, 2006 | 04:15 PM
4DRSpeed's Avatar
Project Ruby......
Very easy to replace the line, just do what Spig did. Only problem I ran into is my Slave cylinder is shot .
Old Jun 22, 2006 | 04:29 PM
RA030726's Avatar
I'm nutty for Nissans
youll need an extra hand (well foot) to bleed the line.
Old Jun 22, 2006 | 06:31 PM
Zack342's Avatar
Thanks Guys. I hsould have specified Clutch line.I got this guy in preperation.
Old Jun 22, 2006 | 07:55 PM
Flava_24/7's Avatar
Boosted Panda
Uh, you did. It was in the title of your subject.
Old Jun 22, 2006 | 09:53 PM
ThurzNite's Avatar
Lol, my bad, missed the "clutch" part.
Jae
ThurzNite's Avatar
Speedbleeder is your friend.
Jae
Old Jun 23, 2006 | 04:02 AM
RA030726's Avatar
Yea I would love those things!
maxima-junky
Oct 21, 2015 05:17 PM
Finkle
Sep 27, 2015 09:53 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maxima-junky
Aug 13, 2015 09:59 AM
