Loose suspension
Old Jun 22, 2006 | 06:33 PM
NYC32798's Avatar
Loose suspension
My suspension feels really loose in the front end. I replaced pretty much every bushing in the front end with the exception of the lower control arm and strut tower bushings. It improved after I installed the other bushings but it still hasn't felt right. It still feels loose. This past week it has developed a loud clunking noise whenever I hit a bump or small dip in the road and it's really getting annoying. It sounds like it's coming from the drivers side. Also it just recently developed a shake in the front end. I don't think the wheels are off balance because I had them done not too long ago and I can't feel a shake in the steering wheel. It feels like theres something in the front end shaking up and down but only at around 60 mph. It won't shake below 60 or above 70. Could the bushings have anything to do with these problems? Any suggestions?
Old Jun 22, 2006 | 09:51 PM
black97's Avatar
Seems like you gotta change lower control arms proly your ball joints shot, also check your axels
Old Jun 23, 2006 | 02:55 PM
NYC32798's Avatar
Ball joints are probably shot since they have 210,000 miles on them. What are some symptoms could be caused by a bad ball joint?
Old Jun 23, 2006 | 04:58 PM
njmaxseltd's Avatar
Check.......................
Ball joints.
Lower control arm bushings.
Inner and outer tie rod ends.
Sturt mounts.
Struts.
Sway bar end links.
Wheel bearings.
Wheels and tires.
Thats pretty much all there is to the front end of a 4th gen Maxima.
Old Jun 23, 2006 | 05:08 PM
Rickalodeon's Avatar
I had symptoms as described in your first post. Additionally, I had a funny sort of drift during sweeping turns and initial acceleration. Problem was a ball joint.
Old Jun 23, 2006 | 06:28 PM
tikiboom's Avatar
I need an intervention
EXACT same problem on mine. Replaced the sway bar end links and its still there. Was gonna do the LCA's next but i dislocated my shoulder so i gotta wait
Old Jun 23, 2006 | 06:33 PM
NYC32798's Avatar
I'm just gonna order all the bushings I haven't replaced including the strut tower bushing and new ball joints. Hopefully that solves the problem. Either way I'm sure they are shot just like all the other ones were. I found ball joints online but in my chilton manual, it says you cannot replace just the ball joints. You must replace the whole lower control arm. Is this true?
Old Jun 23, 2006 | 08:26 PM
black97's Avatar
Yep thats true. There is some places that can press in your new ball joints but it's always better to do it right i.e replace the whole cont. arm
Old Jun 25, 2006 | 01:14 AM
JHowell37's Avatar
I just replaced my ball joints the other day. If you can remove a control arm, you can replace a ball joint.
1. remove control arm from car.
2. place control arm in a vice. If you don't own a vice leave the control arm on the car and remove the knuckle.
3. remove the retaining clip on the ball joint.
4. (I'm hoping you already have your new ball joints waiting to be installed.) I got mine at Carquest. They had them in stock. Spray some liquid wrench on the ball joint as it may assist in removing it.
5. Call your buddy and have him drive you to the auto parts store so you can borrow a ball joint press tool.
6. A ball joint press tool looks like a giant c-clamp. Follow the instructions that are hopefully included with the press tool.
7. press out the old ball joint.
8. press in the new ball joint.
9. Remember to put a little anti-seize on the threads of the ball joint as it will make removing the bolt easier should you have to revisit this area at a later date.
10. Reassemble car.
11. Return tool to auto parts store.
With that said, I also changed my control arm bushings last week. The first one took forever. If you don't have a real oxy-acetylene torch it will test your patience to the limit. After I got fed up with the play torch, I had an epihany. I broke out the Sawzall with a metal cutting blade, and cut the old bushings away from the control arm in a few minutes. At the most the new bushing will require a c-clamp to press in.
I put in ES bushings, but honestly I don't try to kid myself into thinking I've got some kind of race car. If I knew how hard it was going to be to do all of that, and that I could get new control arms for less than $150, I would have bought the new control arms.
Old Jun 25, 2006 | 09:01 PM
NYC32798's Avatar
Well i'm not sure if this would help diagnose the problem or not. For some reason the clunk noise got a lot worse today. It seems to do it not only when I hit bumps now, but it also does it when i'm braking. One time when I was braking, it made the clunk noise 3 times. I got under the car to check the cv joints and they looked good with no rips or tears. This clunking noise is driving me nuts. Anyone have any ideas?
Old Jun 25, 2006 | 11:02 PM
Stock97automax's Avatar
May be a blown strut? Both my fronts are blown and feels the same way.. But i can feel the tire bounce when i hit bad bumps.. Atleast thats what it feels like..
Old Jun 26, 2006 | 04:16 AM
200kMax's Avatar
im thinking now it may be the strut mount. i started developing the same symptoms u have. it sounds very suttle but u can definitely feel the thumping.
i know when i put in my new shocks the threading that holds the shock was getting a bit torn.
remove the strut and check ur mounts. that may be it
Old Jun 26, 2006 | 03:51 PM
NYC32798's Avatar
I'll be replacing all those things next weekend so hopefully one of them fixes the problem. I was driving it in the rain today at 60 and it just felt really unsafe and loose. The one thing I can't figure out is what could cause that clunk noise and at the same time make the front end feel like it's jumping up and down and shaking. I replaced all the struts about 6 months ago and the mounts looked ok but I ordered new ones anyway.
Old Jun 27, 2006 | 07:50 AM
hightuner's Avatar
Nissan maniaco conpulsif
i feel your pain too
i bough lca whit new bushing
also bough sway bar link bushing
i am planning on replacing rack n pinon and (shocks spings) too
Old Jun 27, 2006 | 08:07 AM
MaximaSE96's Avatar
Maxima Owner
loose felling...wierd tire wear and if they brake ur wheel will almost fall off.....be really **** eyed and not drive able....
also check tie rods and such....
Old Jun 27, 2006 | 04:13 PM
NYC32798's Avatar
I think I found the problem. I was able to get it up on a lift today. The ball joints look shot. The rubber on them is shredded so I'm replacing both control arms and that should do it. Thanks for the help.
Old Jul 20, 2006 | 08:49 PM
sagres74's Avatar
Nice!!!
Thx for taking the time to write this up. I recently went to the auto parts store and bought the ES bushings ($35) and the ball joints ($29x2) for my '97. I'll be sure to return them tomorrow and just get the whole lower control assembly w/ everything already installed. For more or less the same price and a smaller headache... I can deal.
Thx again.
10. Reassemble car.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
