drive belt how to = me confused.
Old Jun 23, 2006 | 05:33 AM
willard00's Avatar
ok well, i searched the how to's and found "drive belt replacement" which is what i wanted. i click it and it just gives me a picture from the repair manual. i think i understand the picture, but im not sure. for reference to the how to picture:
http://www.greghome.com/images/Maxim...DriveBelts.jpg
now, tell me if my understanding is correct: so in the picture wherever it says loosen, i loosen that bolt. then once all the bolt are loose the belt will come off? and then i put the new one on the way it looks in the pictures and tighten them? also, thosealso, is there a rental belt tension tool from autozone or anyplace? cause im pretty sure ill need to check the tension afterwards.
if anyone feels like doing a mini write up for me it would be much apreciated. thanks!
Old Jun 23, 2006 | 07:18 AM
ewuzh's Avatar
No tool needed. Use the 90-degree deflection rule. Using your thumb and index fingeers, the belt should twist exactly 90-degrees between the crank pulley and AC pulley.
Old Jun 23, 2006 | 07:44 AM
Chickan's Avatar
yeah, make sure you get the one bolt on the power steering belt. I forgot to take it off, and started cranking on the losening bolt, bent it all up. I still need to figure out how to fix that.
Old Jun 23, 2006 | 12:19 PM
willard00's Avatar
ok just baught the belts, will do them sometime this week. just wondering one thing:
what is the easiest/best way to get to the belts? im guessing taking off the tire and going through the wheel well?
Old Jun 23, 2006 | 12:58 PM
DBear's Avatar
I'm looking to do the same thing. IIRC, the manual said take off the tire and take off the wheel well cover.
Old Jun 23, 2006 | 12:59 PM
ewuzh's Avatar
It's possible to do it just by turning your wheel all the way to the right, but the easiest would be to jack it up, remove the wheel, and remove the plastic splash guard down there.
Old Jun 23, 2006 | 01:11 PM
Black Maxima
I replaced my belt tensioner when I did my alternator the second time. The new idler pully makes the engine so much quieter. I would recomment replacing it if your tensioner bolt is rusted.
Old Jun 28, 2006 | 04:10 PM
DoGGx23's Avatar
In total there are two belts right? One small and one large belt? Can someone explain the process in more detail to replace this? I am going to change the belts this weekend and need your help. Thanks
Old Jun 28, 2006 | 04:11 PM
DoGGx23's Avatar
I don't understand this. What is the 90 degree deflection rule? Do you yank out the belt?
Old Jun 28, 2006 | 04:56 PM
OpieAB's Avatar
How often have you guys replaced your belts?
Old Jun 28, 2006 | 05:14 PM
Fr33way™'s Avatar
Wild for Width
Every 60k or so.
Old Jun 28, 2006 | 05:59 PM
OpieAB's Avatar
Thanx, that means I should probably change mine then since I have 114k on the max right now. Not sure if the dealer changed them @ 39k when I bought it or @ 60k for a major maintence cycle ( 1 of the very few times I ever brought it in to the stealership) but I have never changed them myself that I know.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
markevans999
Oct 25, 2015 08:27 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
