changing head lamps
changing head lamps
ive been looking all over the forums and internet, and cannot find any how to's on how to remove a head lamp unit. If anyone could point me in the right direction as to where i can find a write up on it, or if someone could PM me and help me out themselves, id greatly appreciate it. Thanks.
4 bolts right behind the headlamp. 2 you can see, the other you have to get to by taking out the corners. To get the corners off there is 1 bolt that holds the corner in place on top of the headlamp. If it doesn't seem to move no worries, there is a joint on the outer side of the corner light just kindof pry until you can get your fingers around both sides and pull...it may have to be hard, just unhook the light so you don't rip it out of the socket.
Good luck to you on it. I remember when I first did mine. What a PITA it was cause I didn't know about the nub thing at the bottom. For that I took a long flat head screw driver and pried it between the nub and the thing holding it and popped right off.
the corners pull out kinda hard, they are attatched by a small ball joint type thing, try to look in and pull straight out, otherwise it may break. (i broke my the first one i took out because i didnt pull it straight out)
Mar 12, 2020 12:06 AM
doctorpullit
Jul 20, 2019 09:31 PM
03VQMAX
Nov 10, 2015 03:39 PM
RWCreative
Sep 21, 2015 11:01 AM
