brake and battery light on....
Old Jun 28, 2006 | 07:11 PM
maxjetblack's Avatar
my brake and battery light comes on when the car is started and does not turn off. Anyone know what the problem might be???
Old Jun 28, 2006 | 07:13 PM
JwaxMax99's Avatar
Alternator....or less likely battery.
Old Jun 28, 2006 | 07:36 PM
i just had my battery replaced not too long ago...and last winter i had my alternator checked out as well...
any other suggestions...
thank you all in advance....greatly appreciate your help
Old Jun 28, 2006 | 07:40 PM
wetzelman1's Avatar
i just started a thread like this, another guy did, and now another one. Wouldn't hurt to check out a couple threads or search, but anyways, it's probably your alternator. This is what happened to mine and it's the alternator. Lucky for me there was a recall on 97 maxima alternators so I get mine fixed for free.
I also wouldn't drive your car too much since the battery probably isn't recharging.
Old Jun 28, 2006 | 08:11 PM
Mxrider52's Avatar
I support for what?
Yea definately your alternator. Dont drive it until you fix it or you will get stuck somewhere.
Old Jun 29, 2006 | 10:18 AM
cam_honestiam's Avatar
+1 for Alternator. Do a load and no-load test. Make sure that there are 12V+ under no load and 13-14.5V+ under load across the terminals of your alternator. If NG, check that belt is not loose. You may be in for a rebuild.
Brake light usually means low brake fluid.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
