Just installed RSB
Old Jun 28, 2006 | 07:46 PM
96i30azn's Avatar
Just installed RSB
I got home today and found my stabilizer bar from Cattman. Being the hothead that I am, I couldn't wait installed it right away. Took about an hour with alot of time trying to find rough ground so my ramps wont slip. Then took it out for a spin(did not really spin out... yet).
So I'd thought I'd share the driving experience. My car I all stock.
It seemed to have improved steering, low/medium speed stability, and cornering feel... Car still doesn't feel as grippy in corners as my Cousin's IS300... but hey its a FWD on 15 inchers
I'm a little diappointed that it did not improve high speed slalom feel much... i did a little slalom on the freeway and it felt just about as scary as it did w/o the bar. Maybe I need shocks.
Overall, I would recommend this item. It works as expected and is worth every penny of its 119$ price tag.
Old Jun 28, 2006 | 07:59 PM
konak85's Avatar
its time for coilovers or a nice strut/spring combo. It'll spice things up.
Old Jun 28, 2006 | 08:28 PM
D-Bo's Avatar
Droppin logs
on the coilovers
Old Jun 29, 2006 | 10:44 AM
mindlessoath's Avatar
next time i would recomend the FSB and rear antisway bar. with those two, i wouldnt find much need for a RSB.
Old Jun 29, 2006 | 11:04 AM
nismology's Avatar
O...M...G...
Old Jun 29, 2006 | 11:05 AM
BEJAY1's Avatar
Conecarver
You and me both
Old Jun 29, 2006 | 01:22 PM
ThurzNite's Avatar
Where can I get a FSB? What's the difference between the aftermarket FSB and stock?
Jae
Old Jun 29, 2006 | 01:37 PM
1FSTMAX's Avatar
my handling improved once i removed the sway bar.... i does help somewhat on a stock suspension..
Old Jun 29, 2006 | 06:13 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
Originally Posted by BEJAY1
You and me both
holy answers ill add to that
Old Jun 29, 2006 | 06:15 PM
YoU CaNt SeE mE
bro being the newb u are ill take the time out to correct you on this......everyone get a get out of jail free card heres yours...
RSB = Rear antiSway Bar
Old Jun 30, 2006 | 02:55 PM
96i30azn's Avatar
yeah rear strut bar= RSTB= rear strut tower bar, front strut bar= FSTB
I like to think of it as Rear Stabilizer Bar= RSB to not get confused
If I installed a RSTB and told you I noticed a difference, it would either be phsychological or I'd be lying to you
Old Jun 30, 2006 | 03:27 PM
ThurzNite's Avatar
It's subtle, usually only noticed when driving 9/10 or 10/10.
Jae
Old Jun 30, 2006 | 04:43 PM
konak85's Avatar
thats weird
Old Jun 30, 2006 | 05:52 PM
96i30azn's Avatar
Originally Posted by konak85
thats weird
maybe removed front sway bar ... no bar= less weight over front wheels
Old Jun 30, 2006 | 06:02 PM
ThurzNite's Avatar
In the autox forum, it's been mentioned that there's less understeer w/the fsb detached.
I think the car is more predictable w/o rsb. However I think traction limit is higher w/rsb.
Jae
Old Jun 30, 2006 | 08:08 PM
happyricefob's Avatar
V^___^V
1 RSB will make small difference. lower ur car or get FSTB FSB and RSTB will notice bigger difference
Old Jun 30, 2006 | 10:17 PM
96i30azn's Avatar
Jae
Ok, so I get the impression you're not stupid. I will attempt to explain why there is less understeer with the FSB detached.
First off I will state a few accepted principles of vehicle handling dynamics:
1: your car has better grip when each tire is taking its fair share of load(in other words, tires grip best when each wheel carring 25% of the vehicle's weight)
2: body lean decreases grip because it changes wheel/road angle and also increase weight shift during turns(which distorts the even weight distibution).
Now the FSB increases understeer because it increases weight shift(during turns) between the front wheels(in order to combat body lean, a force must be exterted against it). this results in reduced front wheel grip which means understeer.
Meanwhile, the FSB reduces weight shift between the rear wheels(the front wheels are keeping the vehicle level, the rears dont have to) which results in increased rear wheel grip(as opposed to no FSB).
When something increases rear wheel grip and decreases front wheel grip, it increases understeer.
The RSB does the complete opposite of this because it reduces front wheel weight shift and increases rear wheel weight shift.
Old Jul 1, 2006 | 06:47 AM
1FSTMAX's Avatar
no i meant to say that i removed the rear aftermarket sway bar.. now the rear suspension has room to articulate..
Old Jul 1, 2006 | 09:11 AM
ThurzNite's Avatar
I appologize for your misinterpretation of my post. The post was to direct other members to search the auto-x forum for an explaination. You did a great thing by summarizing the plentiful posts and information regard fsb detachment. I thank you, and I'm sure many more do too.
Jae
Excalibur23
Oct 13, 2015 04:33 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
