Headlight ground points...
Old Jun 28, 2006 | 09:21 PM
jaep0913's Avatar
i was reading the instructions on how to install the grounding kit from vqpower.com, and i cant seem to find the ground point for the driver side. anyone have a better explanation of where it is ? thanks
Old Jun 28, 2006 | 09:35 PM
Mxrider52's Avatar
I support for what?
It is on the right fender(driver fender from inside the car) to the right of the fuse box when looking into the bay. It not to far from the clearance light. Just to the left of it.
Old Jun 29, 2006 | 09:27 AM
99grnmaxgxe's Avatar
Old Jun 29, 2006 | 10:06 AM
wetzelman1's Avatar
yup right there, a little awkward to get to if you have large hands.
Old Jun 29, 2006 | 12:14 PM
jaep0913's Avatar
Originally Posted by 99grnmaxgxe
wow, now how am i suppose to reach there ? what tools did you use ? i just bought a 10mm and 12mm wrenches just to install the kit, now looking at that picture, i think imma need somethine else ?
Old Jun 29, 2006 | 01:54 PM
wetzelman1's Avatar
u can get it with a philips head or socket, I forget what kind it is, but it is reachable.
Old Jun 29, 2006 | 04:39 PM
From experience I can get that bolt off in 2 minutes, I use a regular ratchet and 10mm bolt.
Old Jun 30, 2006 | 11:47 AM
jaep0913's Avatar
so what else do i need ? so far, i got 10mm wrench, 12 mm wrench, and a can of WD-40. the only reason i bought the kit was to make my driving side headlight brighter, and i need to spend twice more on getting tools to install it... wow.
Old Jun 30, 2006 | 12:37 PM
crazy97's Avatar
10, 12 , 14 mm sockets will come in very handy if you ever plan on doing more work to your car, so the money spent on these tools will not be wasted.
You may want to pull your battery if you don't have any swiveling extensions or just can't reach it for some reason. Your 10mm wrench should loosen the battery and terminals.
Old Jun 30, 2006 | 01:20 PM
Batxel's Avatar
blah
If you want your head lights brigher...
2 9004/7 wire harnesses
2 relays (you could suffice w/ one)
20 ft or so of 16 gauge wire
1 solder iron w/ solder
approx $30 pit stop at autozone/walmart
Old Jul 2, 2006 | 02:37 PM
aznxenon's Avatar
Haha I ez-ed took it out by removing the clearance light xD
Old Jul 2, 2006 | 11:46 PM
jaep0913's Avatar
Will that really work ? i was thinking of doing that. Is it reacheable with a 10mm wrench ??
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
