'F1 Racing' ever heard of them
Old Jul 5, 2006 | 06:44 PM
Digital Alchemy's Avatar
Create From Nothing
Started looking at clutches and flywheels on the net. I've already settled on the Findanza Flywheel. Been reading and don't really need a racing clutch since I wont' be pushing 300hp anytime soon. On eBay ive seen Exedy OEM replacement and F1 Racing Clutch Kits for around $130-140. I emailed the seller and he said 'It is a semi-racing clutch made very streetable. It is made by Competition Clutch and/or Clutchnet.' Has anyone heard of or has a clutch kit installed my them. Or should I just stick to looking at the 5th gen OEM clutch.
Old Jul 5, 2006 | 06:48 PM
MaximaSE96's Avatar
Maxima Owner
i have heard of clutchnet..........but not F1 racing clutches...just go with with 5th gen clutch
Old Jul 5, 2006 | 06:59 PM
Create From Nothing
OK does anyone know where I can find them on the net and roughly how much they run
Old Jul 5, 2006 | 07:18 PM
MaximaSE96's Avatar
Maxima Owner
5th gen clutch or F1 racing....of u want 5th gen goto Courtesyparts.com
Old Jul 5, 2006 | 07:28 PM
Create From Nothing
HERE is the F1 racing clutch I was talking about unless someone has heard of them or is currently using one im just going to go with the 5th gen clutch
MaximSE96-->> thanks for you help. i was talking about the 5th gen clutch. on maxmods.dyndns.org they say that you can find it at everythingnissan.com but i couldn't find it
Old Jul 5, 2006 | 07:31 PM
MaximaSE96's Avatar
Maxima Owner
u prolly got to look for it in indivual parts....pressure plate...clutch plate...and throw out bearing....or just give ur local dealer a call.....ask for 2002 parts i believe....i am sure if ur putting down stock power the on on Ebay will be fine...personally I Would go with Genuine NIssan Parts
Old Jul 5, 2006 | 07:36 PM
Create From Nothing
dont have the time, money, or patience at the moment to go anything but N/A. I have a pop charger which is getting changed to a CAI very soon, and im replacing the y-pipe probably next month. Going to finish off the rest of the exhaust once i redo the suspension (Tokico blues w/ GC coilovers Baltimore's roads aint that good), and my audio. I'm not trying to cut corners, im trying to save money. But at the same time I don't want to spend money on something that is cheaper, but wont last as long just cause I didn't want to put up the extra $50-100 dollars
Old Jul 5, 2006 | 07:44 PM
MaximaSE96's Avatar
Maxima Owner
on ur suspension choice if ur roads suck...GC are a bad choice....very stiff....I love my progress for street and TRACk
Old Jul 5, 2006 | 07:51 PM
Create From Nothing
i bought the car 2 months ago from a guy in PA. trust me the road quality is like night and day. he lowered the car 2" in the front and 2.5" in the back he could get away with it up there. Baltimore is murder when it comes to streets. I'm going with the tokico illumina shocks&springs setup, FTSB rear sway bar, and im going to probably redo the bushings. its my first 5spd, and i learned (from my mechanic cussing me out) NOT to ride the clutch. its not slipping bad yet, but when i down shift to 2nd to stop he told me that he & I can feel the clutch not catching properly, its stutters. Can't complain though. The only other times i drove 5spd was dragging didn't have to worry to much about redlights and other traffic
Gismo-T's Avatar
B!tch We Got a Problem
Progress/Illumina
Old Jul 5, 2006 | 08:01 PM
MaximaSE96's Avatar
Maxima Owner
KONI > Illuminas.....but back to clutches......I would spend the lil xtra on the 5th gen stuff it will last longer got more holding power than 4th gen clutch and OEM gooder ness
Old Jul 5, 2006 | 08:16 PM
Create From Nothing
Aight I'll check my nearest dealer and see what price they are talking and then start pricing on the net and see whose cheaper
Old Jul 6, 2006 | 04:33 AM
d00df00d's Avatar
Old enuf to pick his own gears
If you're not making over about 220whp, the 5th gen clutch is BY FAR the best clutch you can get for a 4th gen in every way.
You want 2000-2001 clutch stuff, not 2002; 2002 was the first year of the 3.5L engine, and they switched to a different kind of clutch for that year. You will need the 2000-2001 clutch disc, pressure plate, and throwout bearing. MAKE SURE you get REAL NISSAN PARTS, not "Key Value" which some dealers might try to push on you.
And yes, Koni >> Illuminas, ESPECIALLY with Ground Controls. But try to go with some different springs if you can.
Old Jul 6, 2006 | 04:49 AM
Create From Nothing
ok just to make sure do i have the right part numbers
clutch disc 30100-2Y904
Throwout bearing 30502-41U20
clutch cover (pressure plate) 30210-89F00
do i need the Pilot bearing, and Alignment Tool
d00df00d--> the whole shock&spring setup is coming out. I'm just going to have to do whatever I can to keep my car flat during 'spirited' cornering. is the illumina shock&spring setup worth the price
Old Jul 6, 2006 | 07:09 AM
d00df00d's Avatar
Don't know about the part numbers... Send a PM to DAVEB and ask him. In fact, ask him for prices, too. He is a great source for parts at very good prices. I got my 5th gen clutch kit from him.
About the pilot bearing... I thought our cars didn't use those things. Are you sure you're looking at the right thing?
You only need the alignment tool if you're doing the job yourself, or if the shop you're taking it to doesn't have one on hand that will work on your car.
Suspension wise, I definitely think you should get Koni Yellows with H&R or Progress springs and don't worry about the RSB for now. The Illumina kit is a great product, but while the springs might be good for your purposes, the Illuminas themselves might not cut it. If you want great handling but drive on really rough roads all the time, Koni is the only reliably good choice.
Old Jul 6, 2006 | 07:39 AM
MaximaSE96's Avatar
Maxima Owner
thanx for the correction...i always forget what year to get...i also cross referenced some parts 1999+ S15 Silvias witht he 6 speed use the same clutch as 2001 maximas
Old Jul 6, 2006 | 08:00 AM
d00df00d's Avatar
Holy crap. Are you serious?
That would mean the 5th gen clutch would hold well over 220whp...
Old Jul 6, 2006 | 08:19 AM
MaximaSE96's Avatar
Maxima Owner
http://www.courtesyparts.com/Merchan...Category_Code=
Old Jul 6, 2006 | 08:26 AM
d00df00d's Avatar
That's just the pressure plate... What about the clutch disc?
Old Jul 6, 2006 | 08:34 AM
RedfoxXx's Avatar
dont thye make upgraded clutches for our cars ?
Old Jul 6, 2006 | 08:39 AM
MaximaSE96's Avatar
Maxima Owner
i am sure the disk works as well....i mean the plate has to be same size as the disk to make proper contact....i would imagine they are the same.....or just use a 5th gen disk....the pressure plate gives u most of the holdin power
Old Jul 6, 2006 | 09:52 AM
d00df00d's Avatar
Of course they do. But the point is, unless you're making a ton of power -- i.e. with a highly tuned 3.5 swap, turbocharging/supercharging, and/or LOTS of nitrous -- a 5th gen clutch kit will hold the power just fine, and it will be smoother and easier to use, last longer, and cost a lot less.
Old Jul 6, 2006 | 09:56 AM
d00df00d's Avatar
Yes, you could use the 5th gen disc with that. I just want to make sure because even if the pressure plate fits both apps, it's possible that the splined portions on the clutch discs are different.
Old Jul 6, 2006 | 10:08 AM
MaximaSE96's Avatar
Maxima Owner
very true....i am trying to find an s15 disk part# to cross refernce but its tough not being a USDM model
I am looking and the s15 has 24 splines for the input shaft which would be obvioulsy the splines portion of the disc an and the hole is 25mm in diameter so anyone with a spare disc can measure
http://www.japanparts.com/NissanPart...5/CLutches.htm
Old Jul 6, 2006 | 10:46 AM
Create From Nothing
I lucked to have a mechanic in the family. He is about the only person that I trust to work on my car. I know he has a bunch of them at the garage but I want to make sure we have everything we need when i get the clutch
Old Jul 6, 2006 | 10:54 AM
MaximaSE96's Avatar
Maxima Owner
thye are like 5 bux from the dealer if u dont have one
http://cgi.ebay.com/ebaymotors/ACT-C...spagenameZWD1V
D Mason
Jun 21, 2016 04:43 AM
jsmith24
Feb 1, 2016 12:35 AM
jc53
Oct 12, 2015 05:12 AM
MplsMadMan
Sep 11, 2015 07:54 AM
