HELP? Replace front passenger axle
Old Jul 8, 2006 | 01:40 PM
maxlauj95's Avatar
Help any write up or links that give me some hints on how to replace front passenger axle...Thanks in advance
Old Jul 8, 2006 | 03:27 PM
f550maranello2's Avatar
its in the stickies bro.. check them out... simple repair get the axle at autozone... its lik 60 bucks after u return the old one....
Old Jul 9, 2006 | 04:50 AM
1971240z's Avatar
Sometimes pulling it out can be a challenge. Be careful not to damage the axle seal inside. Tough job to replace in a driveway. Hope you have access to a lift.
Old Jul 9, 2006 | 05:21 AM
MAXorBUST's Avatar
i did this about 4 months ago with air tools and jack stands, your lucky because the passenger side is much easier than drivers side. dont be afraid to pull hard on the old one to get it out and remember there is a coupling about 8 inches from where the axle goes into the tranny there will be three bolts on this to remove the axle, taking those bolts off should really be your only problem. best of luck
Old Jul 9, 2006 | 02:43 PM
dabooki's Avatar
i too have to do this repair, i checked all the stickies and saw only how to repair the cv joint only, not the whole axle itself. any help would be greatly appreciated. thanks
Old Jul 9, 2006 | 05:28 PM
kcryan's Avatar
Cv joint=axle, just dont repair the old one and install the new one, its the same
Old Jul 9, 2006 | 07:08 PM
wannaboostbad's Avatar
Wait when i replaced my PASSENGER/RIGht side axle i had to unbolt it from the block underneath not just simply take the axle nut off then pull it out the driver side was that easy not the passenger side.
Old Jul 12, 2006 | 08:14 AM
maxlauj95's Avatar
Thanks guys.....wouldn't have done without your helps.
Old Jul 12, 2006 | 01:50 PM
darklegend06's Avatar
So you finished? I had the same problem then I said f-it, Took the three bolts off and still didn't budge.
Old Jul 12, 2006 | 04:21 PM
gto400no1's Avatar
good luck with the passanger side, i went to do mine over the winter... the thing was so badly siezed on that when i finally gave up and took it to a shop they couldnt even get it off they had to get another shop from down the street to come and bring a heavier duty air chizzel. passenger side is the worst on our cars, and if you dont have a life it sucks even more, trust me i know...
carguy96
20
Feb 6, 2021 06:21 AM
kingw323
20
Oct 21, 2015 08:36 AM
george__
Aug 18, 2015 07:06 PM
AT978
Aug 15, 2015 06:39 PM
follyburr
Aug 7, 2015 09:50 PM
