starting issue
Old Jul 10, 2006 | 09:03 PM
zeeman's Avatar
starting issue
after i drive my car for a while and engine is fully hot, it took longer than usuall to start my car after turning the car off for a few hours. It never happens in the mornings when the engine is cold. Any idea was causing the longer than usual starting time?
oh, and only sometimes it takes longer to start when the car is fully warmed up.
Old Jul 10, 2006 | 09:15 PM
NmexMAX's Avatar
dot dot dot ...
Sounds like an ECTS problem. Do you have a CEL?
Old Jul 10, 2006 | 09:56 PM
zeeman's Avatar
no cels. ECTS? I thought that only causes ur car to shut off after it started a few times.
Old Jul 11, 2006 | 05:47 AM
NmexMAX's Avatar
dot dot dot ...
Semi related to what you have. Maybe a dying CPS or MAF.
Old Jul 11, 2006 | 06:37 AM
zeeman's Avatar
whats CPS?
Old Jul 11, 2006 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
Crank Postion Sensor.. there are 2 so read up on them in the stickys.
Old Aug 10, 2009 | 09:43 PM
amorak's Avatar
I am having a similar problem. My grand dad's '95 maxima takes liek 5 tries to start after its been run in the hot weather.
Any ideas?
Old Aug 11, 2009 | 07:09 AM
f550maranello2's Avatar
remove the fuel pressure regulator vacuum hose and if i gas is present you have found your problem..
Old Aug 12, 2009 | 05:52 AM
JtzMax's Avatar
Whatchyou say?
Oh so true! Also, check that vacuum line for damage / dry rot. My 91' Max and Stanza for that matter, both had bad FPRs at one point. Not so good for hard starts, and not so nice for the MPGs either.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
