rear brake pad replacement
Old Jul 13, 2006 | 02:05 PM
seanish4042
somebody wanna give me an idea of how long it takes to remove and replace rear brake pads.
i just got charged 95 for labor and 65 for parts. doesnt seem like an hour and 20 min job to me
Old Jul 13, 2006 | 02:08 PM
Dubbya's Avatar
VK56 Inside
Its not. If you know what you are doing, 45 minutes including jacking up the car and taking the wheels off.
Old Jul 13, 2006 | 02:09 PM
f550maranello2's Avatar
come on man i just told u its easy....lol 45 mins 20 mins what ever its still an easy job...
Old Jul 13, 2006 | 04:00 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea it is 7 bolt including the wheels......and turning a pisten with some needle nose pliars. take 15 min.
Old Jul 13, 2006 | 06:39 PM
RedfoxXx's Avatar
just stop turning the piston when you feel it stop, pushing it past that will break a seal and cause a leak
Old Jul 13, 2006 | 07:47 PM
G4nismo's Avatar
1) remove wheel
2) remove caliper bolts
3) remove pads
4) insert new pads
5) compress caliper (turn clockwise....i think, don't tear boot)
6) reassemble
where did you go.....firestone?
Old Jul 13, 2006 | 09:06 PM
if the piston doesn want to turn but the 8 dollar tool form autosone... its a cube with a bunch of nubs stickin out of it... u find the correct pattern and put an extencion with a ratchet and ur golden... if the piston has a hard time going in... then u need a new caliper...
Old Jul 14, 2006 | 01:59 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
It may not take an hour and twenty minutes, but the Nissan service manual has it listed as an hour and twenty, so thats how much a shop is going to charge you for, regardless of how long it takes them.
Old Jul 14, 2006 | 05:54 AM
NAPhi_Shift's Avatar
yeahh... watever the guide states is what a shop is going to charge you :-\
Old Jul 14, 2006 | 07:07 AM
seanish4042
what a pile of ****.
and no, it was a private garage that my dad swears is honest.
been in business 75 years, etc.
blah.
Old Jul 14, 2006 | 07:21 AM
Timothios's Avatar
blah.
They have to make money to stay in business. If you don't want to pay for the labor, do it yourself. The stealership would have charged double that.
Old Jul 14, 2006 | 11:34 AM
Vlasic's Avatar
blah.
What I described IS being honest, thats how EVERY shop works. Every type of job has a time listed in a service manual somewhere and THAT is what the shop will charge you, thats what makes the shop honest.
If the job is listed as an hour and the mechanic ****s up and it tazkes 5 hours the shop still has to only charge you for one hour.
Old Jul 14, 2006 | 11:46 AM
seanish4042
yeah i figured as much. im just pissed at myself for not doing it on my own. but then again how would i know that they had to be replaced.
(car was getting state inspection)
Old Jul 14, 2006 | 11:49 AM
UncleMax98's Avatar
Pretty easy job. 1st time probably takes 2 hours, 2nd time may be 1 hour.
Old Jul 14, 2006 | 05:47 PM
cobiker's Avatar
Since the rear calipers also have the ebrake integrated. Don't you need to remove the ebrake cables?????
Regardless, it will probably take just as much time to jack the car and take off the tires, as is to replace the pads.
Good Luck
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
