?Jack-Stand position?
Old Jul 16, 2006 | 04:45 PM
96mAx2fast's Avatar
Where exactly is the correct place to put the jack stands under the car without damaging/bending anything?! I would like to know for FRONT and BACK. Thanks
Old Jul 16, 2006 | 05:00 PM
matty's Avatar
Garage jack points = where you jack up the car
4 middle circles = place to put jack stands
Old Jul 16, 2006 | 05:17 PM
96mAx2fast's Avatar
Thank you. Im going to use the garage jack points because I cannot locate the inner circle points!!
Old Jul 16, 2006 | 05:20 PM
matty's Avatar
They are along the outside edge of the underneath. Stick your head on there and see. I use them all the time.
-matt
Old Jul 16, 2006 | 05:22 PM
xlr8r's Avatar
you can also hit the two chassis/frame rails inside the four jack points. (the runners inboard of the jacking points in the diagram above.) This decouples the rolling stock from the support point.
Makes a difference when you set up your suspension
Old Jul 16, 2006 | 05:33 PM
96mAx2fast's Avatar
Im actually bleeding brakes and just need to get the car up!!!
Old Jul 16, 2006 | 08:21 PM
MaximaSE96's Avatar
Maxima Owner
then jusr use the rear beam and front crossmember...there are spots for lift points under the car...the front are the "frame rails" the rear and little spots for stands of lift arms in front of the rear tires...not the notches but little spots u cant miss them
Old Jul 16, 2006 | 08:48 PM
Black Maxima
Just don't use the factory jack on a slight hill while installing a body kit. Soon after, you will be finding any jackpoint you can get your hydraulic under. And it is pretty hard with a 3"+ drop and only a couple lug nuts in.
Old Jul 17, 2006 | 05:23 AM
96mAx2fast's Avatar
Sounds like a bad experience!!! I couldn't use the rear because of my RSB. Anyhow, I managed to lift it from the front. As for the back, I lifted it up 1 side at a time. Thanks for the help guys.
Old Jul 17, 2006 | 08:56 AM
maximus_96's Avatar
what if you have a rear sway bar under the rear beam? will jacking up the bar to lift the car damage it?
Old Jul 17, 2006 | 09:26 AM
supazn
definately...
Old Jul 17, 2006 | 10:01 AM
Stagnet04's Avatar
Stick with these and you'll be OK..
Old Jul 26, 2006 | 12:18 PM
TunerMaxima3000's Avatar
dam straight
Old Jul 28, 2006 | 04:19 PM
ivnwu's Avatar
Check your manual. Should be there
Old Jul 28, 2006 | 09:27 PM
Cdg2125's Avatar
Why do you need to jack the car to bleed your brakes?
Old Jul 28, 2006 | 09:31 PM
kcryan's Avatar
cause he doesnt have big wheels???
gavin68
Sep 18, 2021 12:36 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
