question about replacing rear wheel bearing
Old Jul 18, 2006 | 02:23 PM
racin89lx's Avatar
the title says it all. i need to know what i will need to replace the driver side rear wheel bearing. once i get the wheel and brakes off do i simply remove the center cover on the hub and take the bolt off or what? would it be easier to replace the entire hub or go ahead and try to do just the wheel bearing. im not totally sure if i will need the entire hub assembly or just the wheel bearing, but i dont want to do only the bearing if both need replacing.
Old Jul 19, 2006 | 12:35 PM
racin89lx's Avatar
anyone?
Old Jul 19, 2006 | 12:43 PM
Nozama's Avatar
Grumpy old guy
Replace the whole assembly unless you have a press to replace the bearing in the hub.
Remove the brakes the the center cap and unbolt the hub, if the bearing has been going for any amount of time be prepared to cut the inner race which will be stuck on the spindle.
I just used a dremel and some cutting blades until I could crack it with a chisel.
Old Jul 19, 2006 | 03:17 PM
racin89lx's Avatar
so if i replace the entire hub assembly will i still have to cut out the bearing or is that only if i want to just replace the bearing.
Old Jul 20, 2006 | 11:19 AM
UncleMax98's Avatar
Only need to cut if that part of the bearing is stucked (seized) on the spindle.
Old Jul 22, 2006 | 09:38 AM
racin89lx's Avatar
does anyone know where i can find these parts, i seem to be having problems finding them. are the front and rear bearings the same part #? i have tried autozone, oreilly's, and advance so far.
Old Sep 25, 2006 | 06:11 AM
Black_Max_SE's Avatar
same question, I have access to a machine shop at work and would like to just replace the rear bearings. Are the front and rear bearings the same? The auto parts store says they have bearings, but they are not listed as front or rear. Here is the part # K8000-31517 NSK
Old Sep 25, 2006 | 10:18 AM
Any advice would be greatly appreciated.
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
classymax420
Aug 6, 2015 06:35 PM
