'99 ECM/Clutch Interlock Wiring
Hi Guys,
I recently bought a '99 Max that was in a front end colision.
The relay box that is behind the drivers side headlight (Relay Box 2) was damaged, so I got some relays and have been rewiring it.
I managed to find all the wiring in the FSM except for the ECM and Clutch Interlock. For the ECM, I was going to use the same wires as my '95, but I wanted to be on the safe side.
So if someone has a '99 5 speed, can you let me know what wires are on which pins? I believe it uses the relay below. It says black, but the ones in my car were green.
It would be nice to finally get this car running
ok, i'll check my car later on if you want. I have never taken the relay box apart to see the wiring, but it must be pretty straight forward. I just need you to tell me the wires of which relay and I'll take pictures incase i don't know what u want LOL, but that will have to be tonight(work sux)
Sorry, I didn't end up getting internet access again till now.
You can just look at the top of the relay box and one says "Clutch Interlock" on it. Then you can just take the 10mm bolts out of the sides of the relay box. There are 4-5 clips that hold a piece of plastic to the bottom of the relay box. just unclip those and you will see the bottom of the relays. Just find the Clutch Interlock one and you should see what color wires go into the bottom of it.
Thanks!
Thanks!
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
