Car shakes when i hit brakes
Originally Posted by Kevlo911
There have been NO reports of a rack and pinion causing shaking symptoms in a Maxima.
If you have a manual trans then its probably your spark plugs are not firing right when there is no load on the engine so get a tuneup. If you have an automatic then its probably your clutches when your not accelorating or somting?
Why would anyone resurface rotors that warped in the first place????
Resurfacing or machining rotors will only make them thinner and more likely to warp faster. Buy the cheapies at a parts store. My $28 Napa rotors are holding up.
If you do your front brakes and the car still shakes, then its the rear rotors. I say this from experience.
I have the same problem. Shakes at high speeds, and stopping at slow speed i can feel the brakes not stoping consistently. Just put on new brakes, and 2 new rear calipers. Still got the shakes. So the next step is the rotors
Originally Posted by Digital Alchemy
I have the same problem. Shakes at high speeds, and stopping at slow speed i can feel the brakes not stoping consistently. Just put on new brakes, and 2 new rear calipers. Still got the shakes. So the next step is the rotorsThread
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
