rear brakes grinding noise
Old Jul 24, 2006 | 05:29 PM
nart86
Hi, I got new drilled/slotted rotors and PBR Utlimates on my car like three weeks ago and eveything was fine until I realized the mechanic messed up the E-brake, so I went back to him and he took care of that, but now a new problem devolped in the rear passenger side where most of the time when I apply the brakes slightly, a metal on metal sound occurs. (a dragging sound)
It only occurs when I tap the brakes slightly...I also can feel it in the brake pedal. I took it back to them 4 times and nothing appears to be wrong, but they can't seem to find out what's making the noise.
I took it to another shop and he said just wait until the pads wear down and get new ones.
Old Jul 26, 2006 | 01:50 PM
nart86
bump............
Old Jul 26, 2006 | 01:55 PM
Rafal002's Avatar
dont know the exact problem but here a try
did they check the retaining clip for the pads (could be rubbing against the rotor) ?
if everything ok then jack up the car, spin the tire with a friend pulling the ebrake and pin point the noise
or maybe even a lack of antisquel on the backside of the pad? (i never use it and i dont have the noise but just trying to help
i know this isnt the best of help but im trying since you seem so desprite. anyways good luck
Old Jul 28, 2006 | 04:18 PM
ivnwu's Avatar
Make sure the shims are firmly attached to the brake pads.
Old Jul 28, 2006 | 04:22 PM
nart86
problem is solved. my mechanic said when my cuz put on the rear brakes he completely twisted something in the opposite direction (forgot the parts name).
thanks
Old Jul 28, 2006 | 05:11 PM
MrGone's Avatar
Why are you messing with a Maxima if you have a 323i
oh wait, nevermind
Old Jul 29, 2006 | 08:15 AM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
oops wrong thread
Old Aug 1, 2006 | 04:39 PM
nart86
problem is back after greasing everything in the rear... oh and its a groaning sound, not grinding
now, when the mechanic raised the car, we checked both rear tires and it seems that the left side wheel is a lil tighter than the other. Should I replace the parking brake cable? do you think that's the problem
Old Aug 1, 2006 | 04:45 PM
MIXXMAX's Avatar
If it's a moaning sound, could it be your wheel bearings are bad, and rule out the brakes all together?
Old Aug 1, 2006 | 04:50 PM
nart86
no its a moaning and grinding sound. Its def. coming from the brakes. I forgot to add that today after playing around with the e-brake...engaging and then driving a small distance and then reverse.....the problem seems to be gone for now
Old Aug 1, 2006 | 05:53 PM
fisher01's Avatar
Same problem, I 've been trying to solve this groan for over a year. It doesn't make noise everyday, but often enough. You name it, I've replaced it, tried everything, same noise. Now I just live with it.
Old Mar 20, 2008 | 04:15 PM
Audio1's Avatar
I have a 99 Maxima and I have the exact same problem nart and it amazes me that my mechanic doesn't even know what the hell it is. well I think I narrowed it down. I took of the wheel and inspected the braking system my self and observed that on the side that the moaning is coming from (or so I think) the caliper piston is not sitting flush behind the brake pad. It's actually resting on top of a raised surface or what appears to be one of three "bump" that's built into the design of the shim. I think this could be the problem as it's applying additional pressure to the pad causing uneven pressure as you brake.
Let me know if you handled the situation
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
carlosvq30
Aug 17, 2015 11:32 AM
egali045
Aug 16, 2015 01:19 PM
