Trans starting to go?
Old Jul 24, 2006 | 06:04 PM
'96 B-rad's Avatar
Ok so my 96 se has 127k miles on it and sometimes when i switch to reverse or switch to drive from reverse the car just turns off. I have to go into park and restart the car.. so is the trans starting to go? Its rare that this happens but it still does. Any help is appreciated!
Old Jul 24, 2006 | 06:48 PM
NmexMAX's Avatar
dot dot dot ...
Probably something other than your trans...
Any CEL codes, ghost codes? How does the intake plumbing look like, any leak in the intake system? Clean your throttle body lately? What does it idle at?
Old Jul 24, 2006 | 08:37 PM
'96 B-rad's Avatar
I dont know im getting it looked at by my mechanic on saturday when he puts in my new radiator. It idles at ~800 which seems normal and it drives fine. But either as soon as i switch to reverse or when i switch from reverse to drive it just shuts down. But then I restart the car fine and it drives perfect again...
Old Jul 24, 2006 | 09:36 PM
NmexMAX's Avatar
dot dot dot ...
You only answered 1 of my questions.
Old Jul 24, 2006 | 09:43 PM
'96 B-rad's Avatar
I know, I havent checked the codes or anything yet and its 130 right now so all I could do was check how it idles.
Old Jul 25, 2006 | 09:02 AM
gosha's Avatar
http://forums.maxima.org/showthread.php?t=482919
http://forums.maxima.org/showthread.php?t=482663
Check your IACV - my G20 used to choke every time when switching between drive and reverse even after the tranny was rebuilt. Usually when you in reverse you also turn your wheels - PS pump puts additional load on engine while your foot is on brake, malfunctioning IACV is unable to compensate for this extra load and engine chokes - comparing to transmission it's a cheap repair. Good luck.
Old Jul 25, 2006 | 11:09 AM
'96 B-rad's Avatar
Thanks ill get that looked at. I really hope its just that since its soo much cheaper than a new tranny.
Old Jul 25, 2006 | 11:55 AM
willard00's Avatar
my tranny went at about 118000miles. had it rebuilt. same thing u desribed happened to me a couple times. reverse-stall-park-start. turns out it was a dust particle or something blocking a sensor. i just drove it regularly and the dust just washed away and hasnt bothered me since.
what i really noticed when my tranny was going was that it was slipping. and it had an erratic idle. meaning that sitting at a light i could feel it kind of like pulsing. then finally one day driving down the road i suddenly was like "hmm the car seems to be real slow....." so i floored it...couldnt get over 25MPH...yea all my gears were toasted except first.
so basically, if you think its going...take it to a shop. have them diagnos it(usually diagnosis is free), and have it fixed if theres something wrong. it will be MUCH cheaper to fix now, rather than waiting til it goes like i did. cost about $1900 for me to have it rebuilt. and they said i coulda saved money if i braught it in earlier.
Old Jul 25, 2006 | 12:03 PM
'96 B-rad's Avatar
Wow $1900?? I didnt think it was THAT much to get a new trans put in.
Old Jul 25, 2006 | 12:17 PM
bladerunr's Avatar
It will cost more to get a replacement trans than to have yours rebuilt. However, it is not your tranny that needs work. If you try to shift and it won't go into gear or won't move the car once in gear, then you know it's time for a tranny shop. While on this subject, change your tranny fluid.
Old Jul 25, 2006 | 12:44 PM
willard00's Avatar
it actually cost me $2300 but they did rear brake pads too. i figured it wouldnt be more then $400 to do brakes...i mean, even $400 is a lot for pads
Old Jul 25, 2006 | 01:42 PM
darklegend06's Avatar
$2300 for the trans and rear brake pads??? WOW, must be one of those performance pads or something but 400 is a lot.
Old Jul 25, 2006 | 01:51 PM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com > all of you.
Old Jul 25, 2006 | 05:27 PM
willard00's Avatar
trans, rear pads, and rear rotors. my bad...left out the rotors. and i just guessed it cost $400...all i saw was the $2300 total
Old Jul 25, 2006 | 06:01 PM
NmexMAX's Avatar
dot dot dot ...
You =
Old Jul 25, 2006 | 08:23 PM
'96 B-rad's Avatar
Wow I got my pads, shoes and rotors all around for $400 total...
Old Jul 25, 2006 | 08:33 PM
NmexMAX's Avatar
dot dot dot ...
Pads and shoes are you talking aobut..
You could do it next time DIY for less than 1/2 that price if you're not afraid of turning your own wrenches.
Old Jul 25, 2006 | 09:06 PM
'96 B-rad's Avatar
I wouldnt know what to do to change my own breaks and stuff. Could prob figure it out but felt more comfortable having a mechanic do it for me. And 400 for everything seemed like a pretty good deal to me.
Old Jul 25, 2006 | 09:40 PM
NmexMAX's Avatar
dot dot dot ...
Make sure your mechanic didn't break anything in your brake system.
Old Jul 25, 2006 | 09:48 PM
96i30azn's Avatar
maybe he swapped out for drum brakes.
Old Jul 26, 2006 | 06:34 AM
NmexMAX's Avatar
dot dot dot ...
Or Z32 rear conversion..
Old Jul 26, 2006 | 11:57 AM
willard00's Avatar
You =
nope, my parents =
i coulda done the brakes myself...they just like spending money i guess
Old Jul 26, 2006 | 01:18 PM
NmexMAX's Avatar
dot dot dot ...
^^ That's how you came along
Old Jul 26, 2006 | 01:47 PM
Rafal002's Avatar
i know this is alittle of topic, but my transmission has been acting up lately, i checked the fliud and its smells burnt. does anyone has a link to a do-it-yourself? replacing the tranny fluid. and what fluid should i buy?
thanks
Old Jul 26, 2006 | 01:57 PM
Rafal002's Avatar
bump, need help lol
Old Jul 26, 2006 | 04:40 PM
Rafal002's Avatar
bummpp........
Old Jul 26, 2006 | 05:58 PM
'96 B-rad's Avatar
I just checked the codes and got 0505 so no error from there. So theres 2 of the questions you asked me. And yeah when its 130 am and I worked for 9 1/2 hours I guess I dont make much sense.
Old Jul 26, 2006 | 07:44 PM
'96 B-rad's Avatar
If your saying thats what is causing this problem the brake work was on my old max. I got this one about 2 weeks ago.
Old Jul 26, 2006 | 07:58 PM
davemac's Avatar
thanks
http://forums.maxima.org/showthread.php?t=149056
Lots of DIY under Fluids section of forum.
Old Jul 26, 2006 | 09:07 PM
'96 B-rad's Avatar
How do I test my iacv? I did a search but I just found how to clean it..
Old Jul 27, 2006 | 05:40 AM
NmexMAX's Avatar
dot dot dot ...
Haynes manual FTW
Old Jul 27, 2006 | 08:34 AM
kmiller's Avatar
I'm having a similar problem w/ my car and I have just about 122k on it. Just a few minutes ago (car wasn't warmed up yet) I was pulling out of my driveway and as soon as I put it in reverse from park the car cut off. I start the car back in neutral, I rev it up and bit and the car shuts right off again....this happened about 7 times. Once the car warms up though, it's fine. Does anybody know what can be causing this? My mechanic checked the code and he said that it was the front O2 sensor...can this really be the cause of my problems? My main mechanic is moving down to FL today, so when the check engine light comes back on I'm gonna try and pull the code(s) myself.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
Maxboy23
Sep 4, 2015 06:04 PM
trungg86
Sep 4, 2015 04:58 AM
