Rear Deck Rattle Fix
Old Jul 24, 2006 | 09:03 PM
Fr33way™'s Avatar
Wild for Width
I had the car apart this weekend for an event and I spent 30-45 minutes putting it all back together. My car is pretty quiet but I would get an occasional rattle from my rear deck area on uneven surfaces.
If you have never had the top section of your rear seat out basically the rear deck is carpeted on the upper side and plane cardboard (or the like) on the bottom side. This pretty much rests on the wires that run across the rear deck. I simply folded two red shop towels in half and put one on each side between the wires and cardboard and hoped for the best.
It cured my rattles and the car has a more "German" or "Vault-like" feel to it, which is really odd, I had gotten quite used to it. Agian, my car was pretty quiet to start with so the difference may not be night and day but if you are eliminating rattles one by one don't forget this area!
Old Jul 24, 2006 | 09:52 PM
Apparition's Avatar
Ichiban King
right on.. rattles suck.
Old Jul 25, 2006 | 09:13 AM
Zack342's Avatar
not a bad idea
Old Jul 25, 2006 | 09:30 AM
denami's Avatar
was gonna do this today, got the bottom seat part off but the top part i cant seem to get unclipped all the way...ive gotten all the top and side clips off but there seems to be a couple in the middle at teh bottom near the arm rest i cant figure out how to unclip, is there a trick or should i just yank it out?
Old Jul 25, 2006 | 09:52 AM
Fr33way™'s Avatar
Wild for Width
Fold down your (for lack of better term) ski-pass, there are two 10MM bolts holding the seat to the bracket. There is also one 10MM bolt on the lower outside of each side. Once those are loose you should be able to tilt the bottom towards you and lift up, it will slide off the "hooks" that it rests on.
On reinstallation seat the back part of the seat on the "hooks" first. You can reach your hand through the ski-pass and help guide the middle onto the hook. Then just hook both sides and bolt everything back up.
Don't forget to feed your seatbelts through, it's a bish when you discover they arn't there after you tighten all the bolts.
Old Jul 25, 2006 | 10:15 AM
Ruthless's Avatar
yea, I was thinking about jamming something in there as well. My subs really rattle that area for me. Annoying as hell.
Old Jul 25, 2006 | 10:44 AM
aih98max's Avatar
scoobystoned...
hmm sounds like a good idea, ill have to do it. my subs rattle the **** outta that area as well
Old Jul 25, 2006 | 01:03 PM
RA030726's Avatar
I'm nutty for Nissans
Ha and I took all the sound deadining off that bad boy and I still dont have any rattles.
Old Jul 25, 2006 | 02:03 PM
denami's Avatar
ya i just did this, but the majority of my rattles come from the ceiling lining any suggestions of what to do there?
Old Jul 25, 2006 | 04:28 PM
Acerbis's Avatar
I used bubble wrap
Old Jul 25, 2006 | 04:33 PM
Hexon's Avatar
How many shop towels would it take to fix the roof lining? JK...I'll have to try that on my rear deck. I tried velcro, but that didn't work. I even sound deadened the under part of the deck, in the trunk, but to no avail. By shop towel do you mean those paper towel things or just normal rags?
Old Jul 25, 2006 | 04:37 PM
Black Maxima
Okay so you fixed the rear deck rattle. Good job!
What really annoys me is the top left corner of the middle AC vents creak, squeak, and crack all the time. How do I fix that one?
Old Jul 25, 2006 | 05:13 PM
Hexon's Avatar
I have noticed that creaking sound, too, sometimes. It normally takes a lot of bass to get it to creak though. By biggest problem is the stupid GXE rear deck brake light. I could get an SE deck to replace the GXE deck, but that would be too easy, so I opted to completely sound deaden the deck light. It didn't work much. It still vibrates and bashes around like crazy.
Old Jul 25, 2006 | 05:47 PM
Fr33way™'s Avatar
Wild for Width
I didn't post it as if I finished a twin-turbo install...
BTW JSutter 98's FTW that was my only rattle!
Old Jul 25, 2006 | 05:49 PM
Fr33way™'s Avatar
Wild for Width
I think the FSM shows 3M squeak tape in those locations.
I am pretty sure my '98 (possibly 97+'s) already came with those fixes.
Old Jul 26, 2006 | 04:13 AM
RA030726's Avatar
My dads 96 has multiple dash rattles, especially around where the a pillars meet the dash. I did my best to fix them. But damn they are so annoying. Im so glad Nissan addressed the issues and fixed them in the later years.
Old Jul 26, 2006 | 08:53 AM
RedfoxXx's Avatar
rattle fix
http://www.jatan.net/tsbs/056820.pdf
read ur stikies
Old Jul 26, 2006 | 10:44 AM
Fr33way™'s Avatar
Wild for Width
I have read all of those, see any rear deck instructions?
Old Jul 30, 2006 | 09:51 PM
FormorAccordMan's Avatar
second skin damplifier PRO and rattle pad. Just did it last week. Awesome. no more rattles and the sub sounds super clean!
Old Jul 30, 2006 | 09:58 PM
Nissan 6's Avatar
I usually just punch my rattles till they go away.
Old Jul 31, 2006 | 06:01 AM
BigLou93SE's Avatar
Not me. I usually just thorw my open 40oz on the dash, and if that doesn't work...I show it my nine.
Don't mind me, just subscribing ina semi creative way.
raywluce
Mar 10, 2025 09:34 AM
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
