New Wheel Bearings Front How long to I have to replace
Old Jul 26, 2006 | 08:50 AM
hobokenkid's Avatar
Just got the word my wheel bearings are the noise problem. (Front) when going slow clicking sound when turning. I do not drive it much. Is there any damage that can be had by going another 5,000 or so miles. Thank you
Old Jul 26, 2006 | 08:55 AM
xxtavixx's Avatar
I think you're confused. When you're turning, and it clicks that is typically your CV joint. Wheel bearings will hum loudly, and are very load dependant. Meaning they hum when you're going straight a little, but when you turn they get very loud.
If it is your wheel bearing, replace it ASAP. There is no guessing as to how long it will last, typically people replace them immediately because they will lock up on you. You will lose control of the vehicle.
-Andrew
Old Jul 26, 2006 | 12:00 PM
hobokenkid's Avatar
thanks the way i was reading it was the bearings i ckecked out the cv and look brand new no cracks?
Old Jul 26, 2006 | 12:21 PM
95mtlMAXSE's Avatar
shift_Puff
yeah, bring it to a shop for that...find the bearings for $50 to $60 tops or they are ripping u
Old Jul 26, 2006 | 06:09 PM
96i30azn's Avatar
Thats not bearing, thats the CV shaft. My worn bearings made a scratching noise on and off. They were $56 at a Nissan Dealership, but you have to get 2 seals too which were $15 apeice. I had mine installed for 135$ at a local shop.
Old Jul 27, 2006 | 06:54 PM
Wheelie King's Avatar
Bearins are $30 at Advance. Don't wait to do it. I waited and luckily my wheel didn't lock or fall off but I ground down my hub and now I have to replace it before the bearings are replaced. The knuckle is sitting in the shop. That's another $130 for a dealer.
Old Jul 28, 2006 | 06:47 AM
hobokenkid's Avatar
So when i bring this in and they say CV shaft Just get it done? cool I had it in a few months ago and they said it was my rotors? would this be any way it could be?
Old Jul 28, 2006 | 07:47 AM
JPMax's Avatar
What's next!?..
Bad rotors would not cause the clicking sound unless your lugnuts or the brake caliper is loose.
Most likely a bad CV joint.
Old Jul 28, 2006 | 08:07 AM
96i30azn's Avatar
Nope can't be rotors if the sound is clicking, I say stop going to that shop because they are either BSing you to have more jobs or they don't know what the hell is going on. In either case, you can't trust them.
Old Jul 29, 2006 | 07:38 AM
hobokenkid's Avatar
thanks made appt to ck out CV joint Nissan dealership see what they come upwith
vingodine
45
May 21, 2016 12:46 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
