My 96 SE manual clutch pedal is dead and can’t shift…HELP!
Old Jul 27, 2006 | 07:08 PM
sickmen's Avatar
OK…I’ve 1996 Maxima SE with only 90K on it and very well taken cared.
Today my clutch pedal has no tension when I pressed it even I depressed all the way down.
I could start the car but obviously I could not shift the car… about 3 weeks ago I’ve noticed that my clutch pedal has no positive tension until I pressed it half way but it was on and off thing.
I thought my clutch spring is worn or something got stuck but after I drove my car to home and when I try to start the car after 5 hrs and pressed the clutch… it had no tension whatsoever.
It feels like the clutch pedal is hanged by just piece of spring… no more hard positive tension and moreover I could not shift… any thought????
Damn…..
Old Jul 27, 2006 | 07:13 PM
BobK's Avatar
Check the brake fluid in the slave cylinder (by your brake master cylinder). Probably a leak in the slave cyliner hose. There's a write-up on how to replace the hose and bleed the slave cylinder but I don't have search ability so you'll have to find it yourself.
Old Jul 27, 2006 | 07:22 PM
sickmen's Avatar
thanks for your input... brake oil level is good and I could not find any leak on the car or driveway.
BTW, why brake oil Interferes with clutch pedal? just wondering...
thanks
Old Jul 27, 2006 | 07:26 PM
sickmen's Avatar
BTW, my clutch oil and brake oil are all top level.
I don't have search function either... anyone could help?
Old Jul 27, 2006 | 07:33 PM
Apparition's Avatar
Ichiban King
is your friend.. other than that it could be a few things.
Old Jul 27, 2006 | 07:39 PM
eturnl
Uh... Are you guys overlooking the obvious?! The clutch is fooking worn to hell? No? I Dunno. I haven't driven a stick in a while...
Old Jul 27, 2006 | 07:41 PM
WielkiWaac's Avatar
MaximaDriver
maybe your master or slave cylinder went bad.
have someone pressing your clutch pedal and you take a look on slave cylinder (its bolted to tranny) and see if that little piston is moving
Old Jul 27, 2006 | 07:45 PM
sickmen's Avatar
No...I replaced the clutch about 20k ago at the dealer and it's pretty new.
I think mostly likely clutch cylinder problem.
Where's the slave cylinder? anyone has pix???
Old Jul 27, 2006 | 07:48 PM
sickmen's Avatar
anyone know where to find slave cylinder leak fix writeup?
Old Jul 27, 2006 | 07:51 PM
WielkiWaac's Avatar
MaximaDriver
noo. thats a master.
slave is located on tranny, black thing right next to the engine block
http://www.autozone.com/servlet/UiBr...3d801f5563.jsp
first picture where it says clutch operating cylinder
Old Jul 27, 2006 | 08:06 PM
sickmen's Avatar
thank you guys... I looked at the slave cylinder but could not see the trace of oil.
I also traced the line but no leak... I think you guys are right but I could not see any trace of oil.
BTW, how much does it cost to replace the cylinder and bleed fluid at the shop?
Old Jul 27, 2006 | 08:09 PM
WielkiWaac's Avatar
MaximaDriver
usually labor cost is 75$+/hour
Old Jul 27, 2006 | 09:27 PM
BobK's Avatar
Found the write-up: http://www.vqpower.com/v2/modules.ph...howpage&pid=67
Old Jul 28, 2006 | 01:47 AM
Maxtank's Avatar
If the clutch it fairly new, most likely your slave cyl.
Old Jul 28, 2006 | 05:13 AM
sickmen's Avatar
thank you guys! you guys are awesome!
Old Jul 28, 2006 | 06:34 AM
MAXorBUST's Avatar
same EXACT thing happened to me on my 96 SE, i replaced the master cylinder, still wouldn't work, then the slave, and still nothing....i now am driving a beautifully shifting car with its NEW CLUTCH!...sorry man but it is almost positively your cluch...sorry for the bad news.
MAXorBUST's Avatar
Old Jul 28, 2006 | 06:36 AM
MAXorBUST's Avatar
sorry my computer wigged out and double posted...nvm those posts
Old Jul 28, 2006 | 02:07 PM
eturnl
I know people that wear there clutch out pretty fast... I dont know how you drive... but have a mechanic look at it man... and tell him to prove to you what the problem is instead of him just telling you what it is.
Old Jul 28, 2006 | 03:45 PM
dgeesaman's Avatar
Maintenance Monster
If the pedal goes down without any tension it's probably a hydraulics problem like the master cylinder.
It's possible that the problem is clutch, but it's sorta uncommon.
A good tranny shop can diagnose this properly in a matter of minutes. If you really want, remove the intake snorkel (the plastic b/t the battery and engine) and have someone watch the slave cylinder while you work the clutch. If the slave pushes the release fork, it's a clutch problem or something else in there. If the slave doesn't move, it's a hydraulic problem.
Old Jul 29, 2006 | 03:40 AM
sickmen's Avatar
Well, I towed the maxima to a local Nissan specialty shop and they could not find any leak or problem with the clutch pedal that has no pressure.
They suggested air might be in the line and bleed the fluid out and replaced with new fluid. The car worked about a few hrs and now completely dead again.
I need to tow to that damn shop again to fix but does anyone know how to reset something so my clutch pedal could pop up again? I need to make this car work again temporally so I could save the towing… the shop did something and the pedal popped out right again… any thoughts? damn
Old Jul 29, 2006 | 07:29 AM
sickmen's Avatar
I was able to pop out the dead clutch pedal by pumping the pedal about 100 freaking times! after about 100 times of hard action, the clutch pedal finally popped out half way and I was able to drive the max to the shop.
They said since there's no external leak it might be a internal leak problem and will try to replace the master cylinder... hope it works this time....
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
