Suspension Making Noise (pics inside)
Old Jul 27, 2006 | 09:28 PM
NISMOPower's Avatar
I hit a pot hole awhile back, ever since, I've heard wierd noises, sounds like "clunk clunk" So I took my suspension apart and I'm looking for what might cause the noise. My friend took these pics for me was hoping someone could confirm what I'm seeing is right
End link (crooked?)
Close up
Strut Tower (Crooked?)
Old Jul 27, 2006 | 10:33 PM
Sy0p's Avatar
are those sprint springs, i hate those fu&kin things.
Old Jul 29, 2006 | 01:39 AM
NISMOPower's Avatar
Anyone else have an opinion or information on this???
Old Jul 29, 2006 | 03:42 AM
dgeesaman's Avatar
Maintenance Monster
The strut is supposed to be angled like that.
The end link is sorta free to rotate some like a ball joint - take a 12mm wrench and rotate it using the hex in the middle of the link. So right now I don't see anything 'out' there.
Take it to a good alignment shop and have them try to find the problem. It's probably not an expensive fix and your alignment is probably out from the pothole anyway.
Dave
Old Jul 29, 2006 | 03:59 AM
njmaxseltd's Avatar
Pics looks totally normal.
Take the strut apart and check it's operation.
Inspect the ball joint, tie rod ends both inner and outter.
Inspect the strut mount.
Inspect the lower control arm bushings.
Reassemble the strut correctly, make sure the word OUT on the upper perch lines up with the lower strut mounting flange and make sure the spring seats evenly in the upper rubber seat.
Test drive and report back.
Old Jul 30, 2006 | 06:44 PM
Wheelie King's Avatar
Wheel bearing starting to go? I had a nasty clunking noise when mine started to go. I heard it on the left side when I turned right, putting weight on the left side. I also had a humming noise.
Old Aug 3, 2006 | 11:30 AM
Allens96SE's Avatar
Hello All, My suspension is also making noise, but more of a quick squeak, it's only when I go over speed bumps or hit potholes. Does anyone have any idea what this could be? it sounds like it's coming from the drivers side strut.
Old Aug 3, 2006 | 12:02 PM
southeast_first's Avatar
^ i have the exact same thing... i ordered new lca's, inner and outer tie rod ends, and sway bar end links. if that doesn't fix the problem, at least my car will drive a little better until i get around to fixing the noise :-/
Old Aug 3, 2006 | 06:00 PM
dgeesaman's Avatar
Maintenance Monster
swaybar bushings have given me the squeaks on more than one occasion. I'm talking about the bushings under the steering rack that wrap around the bar - take them off and look to see if the metal bracket has sawed thru and rubbed the metal of the bar.
Old Aug 14, 2006 | 08:34 PM
NISMOPower's Avatar
hey guys, thanks for all the help and comments, haven't got a chance to work on the maXipad as i've been out on vacation in Vegas
i'm also hearing a very slight humming as well... not constant but consistant though, definately repetative
i'll report back soon as i get a chance to work on it
Old Aug 15, 2006 | 06:21 AM
willard00's Avatar
this answer is way out there, but it it happened to me thats why im suggesting it lol...
if uve done any recent brake work (or maybe not) check the caliper bolts. i hit a pothole and one shook loose and i was hearing clunking sounds (which ended up being my caliper against my rotor). bolt eventually fell out, but luckily i heard it n was right down the street from my house.
Matt93SE
May 24, 2019 02:58 PM
Quickgtp
Apr 13, 2017 03:30 PM
maxinout93
Oct 27, 2015 01:29 PM
95Maxi
35
Sep 2, 2015 10:37 AM
