Front Strut Bar
Old Jul 31, 2006 | 07:22 AM
2k2maxima's Avatar
Front Strut Bar
Hey guys,
Just got my front strut bar..about to install it - Just wanted to make sure..what do I set the torqure wrench on? If I remember correctly, I think it was 32 lb...just wanna verify again becasue I can't seem to fnid the link.
Thanks in advance.
Old Jul 31, 2006 | 07:25 AM
kcryan's Avatar
i seem to recall 36, but i did mine a while ago so i might be wrong, either way lots of people im sure dont bother to torque them down so if your in that area your good...
Old Jul 31, 2006 | 07:26 AM
kcryan's Avatar
then again my manual seems to say 40, so lets get some confirmation here haha
Old Jul 31, 2006 | 07:30 AM
Gismo-T's Avatar
B!tch We Got a Problem
39-54 Ft Lbs.
Old Jul 31, 2006 | 08:29 AM
denami's Avatar
ok, so what if you dont have a tourque wrench how do i know what 39-54 ft lbs is because my strut bar should be here within the next few days...
Old Jul 31, 2006 | 08:42 AM
RedfoxXx's Avatar
If it clanks around add more torq, if you strip the bolt, add less torq
Old Jul 31, 2006 | 08:47 AM
kcryan's Avatar
Rent or borrow one....
Old Jul 31, 2006 | 08:49 AM
Cdg2125's Avatar
Yeah I never torqued mine. Don't have a wrench so I just depend on my own hand. Hope that's not a bad idea haha.
Old Aug 3, 2006 | 11:26 AM
Allens96SE's Avatar
Does the front strut bar add a noticably stiffer ride through corners?
Old Aug 3, 2006 | 11:42 AM
Timothios's Avatar
It noticably reduced my understeer!
Old Aug 3, 2006 | 01:07 PM
Dubbya's Avatar
VK56 Inside
Stage I Lower Tie Bar > Any FSTB
Matt Blehm makes them. Blehmco.com or something like that.
Old Aug 3, 2006 | 01:16 PM
happyricefob's Avatar
V^___^V
32lb/ft..........
Old Aug 3, 2006 | 04:40 PM
2k2maxima's Avatar
i set mine at 45..im guess thats too much...? i started to hear some 'creaking'/clanging noises now...dont' kow if its too tight, or i need to tighten it more..any input.
thanks.
Old Aug 3, 2006 | 09:22 PM
d00df00d's Avatar
Old enuf to pick his own gears
Most intelligent response in the history of the .org.
Old Aug 4, 2006 | 07:18 AM
Allens96SE's Avatar
Does it really matter what brand of strut bar you buy? is Stillen any better than others?
Old Aug 4, 2006 | 07:25 AM
JPMax's Avatar
What's next!?..
They all do the same thing. Only things different are the materials, look, and price.
Old Aug 4, 2006 | 07:27 AM
aznsap's Avatar
if you plan on getting an 00vi, you might want a strut bar tha rises up a little higher so it'll clear the manifold.
Old Aug 4, 2006 | 07:31 AM
Allens96SE's Avatar
What kind of Strut Bar does rise above the manifold? Also, where would one acquire an 00vi? and approx how much do they cost?
Old Aug 4, 2006 | 09:02 AM
Cdg2125's Avatar
Go look in the FS forum. They have some. Junkyard may have one. Not cheap and alot of work.
Old Aug 4, 2006 | 10:48 AM
evil_spork's Avatar
on the order of $600, and a good deal of work to get it installed properly.
btw, the creeking youre hearing means you torqued too much, back them off to 32lbs. you risk breaking a bolt with them torqued too high.
Old Aug 7, 2006 | 11:37 AM
Allens96SE's Avatar
Hey, does anyone know anything about the BOMZ strut bar? will it rise above the 00vi?
Old Aug 7, 2006 | 12:05 PM
MaximaSE96's Avatar
Maxima Owner
torque wrench...pssssssssssssss....crank mine down with my impact gun...never had an issue
Old Aug 8, 2006 | 01:59 AM
FishyMan's Avatar
IMO, I think a strut bar should be STIFF, SOLID not cheapo **** like ebay.
The bomz DETACHABLE makes the middle of the bar a weak point as you can literally screw and unscrew.
Think about a chopstick versus a tooth pick. Materials are ALWAYS at stake when involving cars.
Sadly STILLEN = RAPE. CATTMAN = RAPE too..
Our cars are big, heavy, so I would feel better using something THICKER.
But for 4 bangers, just use the typical ****.
Old Aug 8, 2006 | 06:35 AM
d00df00d's Avatar
My Alutec bar is the widest one I've ever seen for the Max, and it clears my '00VI just fine...
lowpost99
Oct 26, 2025 06:53 PM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
