Water Pump Replacement
Old Jul 31, 2006 | 08:45 AM
unkadave11's Avatar
It appears that my water pump seals have gone bad and I'm getting coolant dripping out from between the front wall of the oil pan and the ac compressor/alternator area. I have read the instruction in the how to section and just want to know if there is anything else that I should be aware of.
Also if it is just the seals that have gone bad do you think that I should try something that you put in your radiator to fix leaks and hope that it resolves the problem with the seals? I don't know much about the water pump.
Old Jul 31, 2006 | 08:51 AM
matty's Avatar
This is a really good write up. I used it when I did mine. I wouldnt use any of the leak fix stuff.
http://forums.maxima.org/showthread.php?t=308680
Old Jul 31, 2006 | 10:11 AM
unkadave11's Avatar
Thanks matty, I've already read this write up several times and will be using it as my guide. Did you run into any problems? How long did it take you to complete the job?
Old Jul 31, 2006 | 10:50 AM
matty's Avatar
Didnt take all that long. I have my blower on there so taking off the blower first then doing the job took a bit more time.
Only real problem is the lack of space you have. Just be patient and dont get ahead of yourself. Shouldnt have a problem.
-matt
Old Jul 31, 2006 | 10:55 AM
i30ds's Avatar
Armed and Dangerous
And don't be alarmed by the load noise from your engine after you install the new one. It will subside in a few minutes.
Old Jul 31, 2006 | 11:28 AM
unkadave11's Avatar
Thanks for the help. I'll be doing it after work today.
Old Aug 3, 2006 | 09:18 AM
unkadave11's Avatar
I wanted to say thanks for the help on my water pump issue. I put the new pump in three days ago and have no problems since. The job was not as hard as I thought it would be but I guess that is because I had good instructions to follow.
Old Aug 3, 2006 | 09:28 AM
matty's Avatar
Good Job. Replacing a water pump isnt the easiest of jobs.
-matt
Old Oct 16, 2007 | 12:40 PM
scooby68's Avatar
Hi Matty, Where might I find this post, its been corrupted or hijacked. Thanks. Vinc
Hi Matty, Where might I find this post, its been corrupted or hijacked. Thanks. Vince
Old Oct 16, 2007 | 12:55 PM
andrei3333's Avatar
replace "show" with "old" in the link name
and check out the other thread you messaged on just some time ago
00MAXI
Sep 2, 2015 10:23 AM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
