Help with clearence lights problem.
Old Jul 31, 2006 | 08:35 PM
bigpulve+'s Avatar
So I am having this very weird problemo. My tail lights are not working and my clearance lights wont come on when i turn the lights on. The clearance lights come on when I brake. So I was thinking that I blew a fuse or something. The only thing I did was put in some new outter tails that I got from chillian in the classified section. I used the stock wiring harness and bulbs from my car. What the hell did i do.
Old Aug 1, 2006 | 04:29 AM
Cdg2125's Avatar
Did you check the fuse before posting this or just think about the fuse being bad?
Old Aug 1, 2006 | 12:43 PM
bigpulve+'s Avatar
I just thought about the fuse being bad. If it was blown I would have replaced it, but I plan on checking tonight. Anyone have any ideas?
Old Aug 1, 2006 | 12:53 PM
black_maxed95's Avatar
most likely a fuse since they work when you brake
Old Aug 1, 2006 | 02:40 PM
97GreenMaxSE's Avatar
yeah most likely a fuse
Old Aug 1, 2006 | 03:15 PM
bigpulve+'s Avatar
The brake lights dont work when I brake the clearance lights come on when I brake.
Old Aug 1, 2006 | 04:51 PM
Cdg2125's Avatar
It's wired incorrectly. Take it apart and put it back together. Then see what happens.
Old Aug 1, 2006 | 06:44 PM
metallic97gxe's Avatar
Master Will
.............or you have a bad/shorted out brake light bulb check all of your bulbs....
Old Aug 1, 2006 | 07:05 PM
nitromax's Avatar
double check that you don't have a single contact bulb in a double contact socket and vice versa. wrong bulb in a socket can cause this problem.
Old Aug 1, 2006 | 07:06 PM
maximaSE327's Avatar
i had the same problem... for me it was just a blown fuse
Old Aug 1, 2006 | 07:17 PM
sorry i read wrong
if your clearance lights light up when you brake it has to be wired wrong then.
Maxie40
Sep 14, 2015 11:28 AM
markevans999
Sep 10, 2015 04:29 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
slowlifer
Sep 8, 2015 05:53 AM
Maxima30
Sep 7, 2015 06:13 PM
