I'm doing a 5SPD SWAP!
Well if for some reason you do need to unbolt the tie rods, there is no need for that for that special tool. Like "praetoryan" said, just take a hammer and smack the hub right where the tie rob bolts up and it will pop right out, just make sure you dont hit the tie rod.
Originally Posted by Black Maxima
This thread is really alive now.
How hard is a flywheel to take off a parts car?
no way, i changed my pass side axle, and needed no tie rod popper, just drop the 2 bolts on the shock, pull off the big nut, and a few other small things ( like moving the brake line outta the way) and ur good to go. they pop out...
I don't recommend using the stock clutch lines. For my car I used the SS clutch line connected to a Raybestos custom bend brake line. It's much much easier to bleed and install. I've had no problems after 10k+ miles.
I will worry about the lines after everything works for sure once installed. I want to upgrade to SS lines.
A couple more things. I will need to get a manual starter? And also a manual transmission mount? Is it possible to get these parts used? I am looking at a parts car right now. Or do I have to buy them new?
Not flaming but have you read the 5-speed swap parts list sticky in the all-motor forum?
Honestly you shouldnt even bother with getting stock lines, they are a HUGE pain in the *** to manage, just start with a SS line that goes directly from the master to the slave. It will save you SO much time during install and bleeding.
Originally Posted by darklegend06
I heard the spacer is welded on to the firewall, Can someone draw me what is supposed to look like? If not PM me an offer for it.
but ill try and see if i can get a good look at it and tell you whats there.
No there isnt, that thing that looks like a spacer is part of the clutch pedal assembly.
Here is what the spacer looks like:
Damn, kid! If you lived anywhere near me, I would TEACH you!
I can't
the 5th gen clutch kit enough. Thinking about using ANY other clutch on any NA non-nitrous 3.0 Maxima literally makes me laugh.
Big
on the SS clutch line too. Soooo nice.
Also, if you can, try to get new master and slave cylinders. Those parts can definitely tire out with mileage.
I can't
the 5th gen clutch kit enough. Thinking about using ANY other clutch on any NA non-nitrous 3.0 Maxima literally makes me laugh.Big
on the SS clutch line too. Soooo nice.Also, if you can, try to get new master and slave cylinders. Those parts can definitely tire out with mileage.
Originally Posted by Blackwind
you have a 5spd ecu? are you getting codes?
Auto ECU. Along with the 3.5 swap, I have enough codes to fill a 500 page novel.
But seriously, I have about 6 a/t codes. 12 codes in all...evap, egr, iacv, aps, etc.
The car runs fine.
