Power steering fluid
Old Aug 4, 2006 | 08:07 PM
DBear's Avatar
The owner's manual and the FSM both say Dexron II. Chilton's says Dexron III. Nobody seems to carry II anymore. So what do I use? Can I use III, or do I have to find some hole in the wall shop that hasn't turned over its inventory in 15 years? (I'm just topping off, not replacing.)
Old Aug 4, 2006 | 08:30 PM
matty's Avatar
Mobil 1 ATF
-matt
Old Aug 4, 2006 | 10:32 PM
WhiteMax96's Avatar
Same for me Mobil 1 ATF synthetic.
Old Aug 5, 2006 | 01:58 AM
goldmax's Avatar
Dextron III. Mobile 1 ATF might be fine if it's rated for Dextron III. Whatever you do, don't use the stuff marked as Power Steering Fluid.
Old Aug 5, 2006 | 04:01 AM
njmaxseltd's Avatar
Amsoil ATF
Old Aug 5, 2006 | 05:11 AM
spadez911's Avatar
so you guys are saying use Mobil 1 Automagic Transmission Fluid???
Old Aug 5, 2006 | 06:50 AM
Kevlo911's Avatar
Kevlo for President
Yes.......
Old Aug 5, 2006 | 09:36 AM
InfinitiJ30's Avatar
I thought he wanted power steering fluid???...
Old Aug 5, 2006 | 09:48 AM
Mxrider52's Avatar
I support for what?
Why not use the stuff marked for power steering? I poured some of it into my container. Is it gonna hurt something? More info please.
Old Aug 5, 2006 | 09:54 AM
Kevlo911's Avatar
Kevlo for President
Nissan uses ATF... PS fluid is similar to ATF tho.
Old Aug 5, 2006 | 10:02 AM
matty's Avatar
"Some power steering units require certain additives not commonly found in ATF. As such, specialized PS fluids contain the additives. Honda and GM come immediately to mind as being very picky about their PS fluids. Nissan units do not require these additives and run happily on ATF (D-II) . I can't say for certain what the effects would be if you were to use off the shelf PS fluid in your unit, but I agree with sbddude...stick with either ATF or use Nissan power steering fluid if you feel the need."
"For what it's worth, I have used AMSOIL synthetic ATF in my power steering units for years and have installed it in several customer's cars...the synthetic fluid reduces operating temperatures of the PS system contributing to component reliability, longevity and seal integrity."
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
