SRS Light Flashing
Old Aug 6, 2006 | 05:57 AM
99 Max ES's Avatar
SRS Light Flashing
What the hell does this usually mean?
car was never in wreck.
Old Aug 6, 2006 | 06:07 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
passenger airbag failure in the seat ill bet 10 to 1. from what ive found the harness goes bad since its too short and over time just goes bad. mines been flashing for months now. its a frekin 300 dollar part. im planning on removing the harness and rebuilding it soon.
Old Aug 6, 2006 | 09:56 AM
99grnmaxgxe's Avatar
I think this is in the stickies, might have to do something with your tranny.
Old Aug 6, 2006 | 12:10 PM
seanish4042
judging by your user name you know little about your car.
stickies.
Old Aug 6, 2006 | 12:29 PM
CRiME's Avatar
oem ftw!
stickies.
actually there is an ES model maxima. idk the differences, but they can be found in canada. Maybe the OP is canadian.
Old Aug 6, 2006 | 01:15 PM
96blkonblkse's Avatar
ES is basically an se with no leather package or spoiler.
in both my 98's the airbag light is flashing, i asked my freind and he said the airbags will NOT go off.
Old Aug 6, 2006 | 01:18 PM
99 Max ES's Avatar
stickies.
Judging by this post you dont know all there is to know about Maximas.
Don't let the Newbie status fool you. I've had a 4th Gen Maxima since 99, bought it new. and it was an ES.
Old Aug 6, 2006 | 01:24 PM
seanish4042
i stand corrected. odd.
Old Aug 6, 2006 | 02:21 PM
Oh $hit my bad, I thought it was your O/D light flashing, your tranny is probably okay.
Old Aug 9, 2006 | 10:35 AM
CUR167's Avatar
I have the same issue with my car, tried to reset using the stickies but it did not work. Just got the dealer's manual in a CD from a friend, it has a step to trouble shoot it, I will try to see if it works. But if anyone know how to fixed i will appreciate it.
Old Aug 9, 2006 | 11:47 AM
GodFather's Avatar
Made in Taiwan
This will be good to know. I'm planning on keeping the car forever, so if mine goes off like this I can fix it too. Please come back with your troubleshooting results.
-Peter-
Old Aug 9, 2006 | 12:38 PM
showoff's Avatar
listening!!
Old Aug 9, 2006 | 12:55 PM
bhunter's Avatar
The procedure for resetting the airbag in the stickies is wrong.
Old Aug 9, 2006 | 01:18 PM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
as mentioned above, if your car has side airbags, its probably the wiring under the front seats. you might need to wiggle around those harnesses.
here is the procedure to reset the airbag light:
1. open the driver's door and get in. leave the door open.
2. turn the key to the ON position (not ACC, not start engine, just ON).
3. push the door pin switch (its covered in a rubber thing near the door sill that controls the interior dome light) at least 7 times within 10 seconds of performing step 2.
4. turn key to the OFF position.
5. close your door.
6. turn on the car.
this should reset the light. it has worked for me.
Old Aug 10, 2006 | 09:27 AM
showoff's Avatar
bump...anyone know which wires to look at?? I still can't get the light off.
Old Aug 10, 2006 | 03:34 PM
Starsnstripes's Avatar
Old Aug 12, 2006 | 06:17 AM
showoff's Avatar
bump...help please
Old Aug 12, 2006 | 06:37 AM
Frank Fontaine's Avatar
5. close your door.
6. turn on the car.
I went through that ritual for nearly 24 mos, very annoying, yet at the same time feeling confident I didn't want to pay the dealer $700 for nothing. About 10 mos. ago, I actually unplugged the side airbag on the driver side, and replugged it. Long story but my entire seatback fell off because the dealer replaced the seat cover under warranty. Ever since then, it never came back. Why I knew it was my driver's side (pass side module was replaced under warranty) was that it would begin blinking as soon as the seat position were changed. I even let a couple short people drive my car and after putting the seat back to where I need it, no blinking/flashing lamp.
To verify the system is working, the airbag lamp should light every time the ignition is turned on, then it goes out. If that's not happening, there's a serious issue.
Old Aug 12, 2006 | 06:39 AM
showoff's Avatar
If I look under the passenger seat, which wires control the airbag??
Anyone have any pics?
Old Aug 12, 2006 | 08:16 AM
96i30azn's Avatar
Take off the back of the seat and see for yourself, I believe its held on by 4 clips
Old Aug 12, 2006 | 10:52 AM
maximaman10's Avatar
You may just need to reset the light. Just turn the key to the on postion then push you drivers door dome light switch five times as fast as you can then start your car. It may take a few times to get it to reset.
Old Aug 13, 2006 | 01:25 PM
showoff's Avatar
so, i just take the seat back off. Is it the piece that has the pocket on it??
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
intimidator
Sep 5, 2015 07:23 PM
