reset
Old Aug 7, 2006 | 03:41 PM
maxfeen's Avatar
reset
after reseting the check engine light will it come back on again after driving it for a while?
and if it does what is the point of reseting it?
Old Aug 7, 2006 | 04:04 PM
HomeLan's Avatar
ok, here's a dumb question...did you pull the codes and actually fix the problem? CEL will just keep coming back until the problem is fixed.
Old Aug 7, 2006 | 04:05 PM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
if the problem is legitimate, the light will come back. the point of resetting it? sometimes the computer registers something as a problem that really isn't a problem. (technically speaking, there is an analog-to-digital converter onboard the computer that converts various continuous voltages to discrete voltages, and if a particular voltage is right smack on the threshold of a discrete value, it might consider the voltage to be to be bad and cause a CEL.)
example: i got an EVAP code not too long ago, so i bought some high quality gas, made sure the gas cap was on good and tight, and reset the code. it hasn't returned and it probably won't... just one of those random voltage things.
Old Aug 7, 2006 | 04:07 PM
darklegend06's Avatar
yeah there is a sticky on how to check for CEL and how to decode it.
Old Aug 7, 2006 | 05:03 PM
Cdg2125's Avatar
there is no point in reseting it if you dont fix the problem.
Old Aug 7, 2006 | 05:36 PM
njmaxseltd's Avatar
Did you actually open the hood and check your engine?
Old Aug 7, 2006 | 05:42 PM
svojs's Avatar
Man, at least you need to check what code it is before you reset it. Then make necessary fix. If you just reset the CEL without fix, yes, the code will come back.
gigabyte
Jan 6, 2017 06:05 PM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
vrajesh123
Sep 22, 2015 04:20 AM
Colossus
Sep 9, 2015 05:46 AM
