Car Jerks, what could be wrong?
Hi I need some help. My 99 maxima started to idle really rough and it jerks at idle. Once I accerlerate, the car would jerk a bit and the rpm would drop a bit. This problem goes on all the time, its not like an off and on thing. The next thing is that when I reverse to get into my parking space, the car seems to jerk and idle really low, then it would like almost stall out. During that point, i would see the oil gauge light blink couple times. What can this problem be? I would like to get it fixed asap. Thanks alot guys
Get you some new or used coil packs, ASAP! You need to replace all 6 to get your max back to smooth running. You have 1 pack that is dead right now. That's where the bucking and low idle is coming from. 1999 Max coil packs suck
Originally Posted by ancientwiseone
I replaced all 6 of my coils last year already. The next thing is that wouldn't it trigger a code if my coil went bad?
As for your problem, the post a few above is on the right track. Check your filters (air, fuel), spark plugs, clean TB & IACV, etc.
Originally Posted by dgeesaman
Even though you're calling us "car jerks", I'm still going to suggest checking the coil packs
mines doing the same, let's check the group deals shall we and see what's available. I need coils and a whole new exhaust line. Talk about loss of power, civics beat me
My 95 auto, couldn't be better, i might switch them out from one to the other
not nessacarilly(spelled that horribly.)....took me like at least a month to finally get a code.
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
laparka66
Aug 6, 2015 09:36 AM
