96 GLE with ABS light on
Old Aug 10, 2006 | 04:58 PM
t6378tp's Avatar
Turbo 3.5
Hey, I was looking to buy a 96 gle but the abs and cel on both on. I know how to pull the codes for the cel but not the ABS. Is there anyway to pull the ABS codes and if not what could be wrong and what should I look out for. I can get the car for cheaper most likely cause of these problems I do not care about fixing them if it is cheap repair.
Old Aug 11, 2006 | 07:37 AM
spadez911's Avatar
ABS Sensor maybe bad
Old Aug 14, 2006 | 07:14 PM
t6378tp's Avatar
Turbo 3.5
any other ideas. or is that pretty much it
Old Aug 15, 2006 | 04:08 AM
SMX95's Avatar
Lets not assume here. You don't diagnose by stating a "Maybe" statement.
ABS is a another animal. You need a ABS scanner for that. The most you can do is look at each ABS tone ring and look for any crack(s). If there is a crack the space between the crack and the ring will set off a abs light. You can also have a bad ABS speed sensor, You can also have a bad ABS module. IF you have no access to a ABS scan tool or a way to lift your car then I highly suggest you bring it to someone that has a ABS scan tool and knows how to diagnose the problem well. You DON'T just guess on things.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
