removing corrosion inside wiring harness?
Old Aug 11, 2006 | 05:44 AM
wetzelman1's Avatar
So one of my taillights had been out for about a month, not that big of a deal. I had tried changing the bulbs and that hadn't done it so I didn't really feel like paying someone to rewire the light. So I was messing around with it the other day and I got the bulb to come on by pushing the harness connectors together really hard but it won't stay on. I pull them apart and see the connections are all corroded. Now I can't really get anything inside it to scrape the corrosion off. Is there anything I can do to make it work again?
Old Aug 11, 2006 | 09:15 AM
Kazoo's Avatar
They sell electrical contact cleaner at auto part stores. You can give that a shot to see if it would work.
Old Aug 11, 2006 | 10:29 AM
xlr8r's Avatar
an eraser like what you get on the end of a pencil is pretty handy at cleaning electrical contacts. However, it's a pita if you got a lot of them or they're covered in crud & fonge.
A small steel wire brush or steel wooll if you can get into the contacts.
Old Aug 11, 2006 | 10:40 AM
JPMax's Avatar
What's next!?..
fine sandpaper works well too.
Old Aug 11, 2006 | 06:16 PM
Motorhead52's Avatar
Electrical contact cleaner is the way to go, it's designed to remove corrosion and protect from moisture. Just get a spray can, put on some safety glasses and soak the connecter down for a moment. Then use the pressure from the spray to blow off all the corrosion and your good to go.
Old Aug 12, 2006 | 02:29 PM
nitink's Avatar
liberally spray wd40 and let it stand for 10 mins. After that put a tissue paper to soak wd40,
If you can touch connector remove rust by your hand and tissue paper.
Otherwise use a brush to clean it.
Wait till connector is dry (hint you can use a hair dryer) before installing anything
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
