FPR or FUEL PUMP?
Old Aug 13, 2006 | 10:24 AM
seanish4042
FPR or FUEL PUMP?
i have had crazy problems with misfires etc. for the past month.
the other day, the problem switched from a misfire, to a reallllly hard start where i have to give it a LOT of gas. i ahve had problems starting for like 2 years....have to turn the key and prime the pump a few times and it still wouldnt start easily. i also used to be able to hear a groan coming from somewhere when i would turn the key....now nothing. the car now shudders all over the place at idle. i was out with a girl last night and she was like 'yeah so your car is shaking liek crazy' i was like yeah i think its the fuel pump.....and i have that gay surging acceleration. although at WOT after 3000 it seems normal.
how do i know whether its the pump or the fuel pressure regulator?
Old Aug 13, 2006 | 02:43 PM
seanish4042
bump bump bump
Old Aug 13, 2006 | 02:53 PM
NmexMAX's Avatar
dot dot dot ...
Check your fuel pressure.
Old Aug 14, 2006 | 10:28 AM
seanish4042
bump.
i guess i ask my boy who has a 97 I30 if i would borrow his fuel pump to see if thats the prob.
also. VERY VERY odd.
lately, when i rev up the engine...on the way back down...i hear one or two loud thuds. imagine hitting an empty tin can with a stick. like something is hitting something else...or there is some electrical spark or something. I will take a vid later and try to post it.
any ideas?
Old Aug 14, 2006 | 10:59 AM
NmexMAX's Avatar
dot dot dot ...
Old Aug 14, 2006 | 11:02 AM
MaximaSE96's Avatar
Maxima Owner
lather, rinse, repeat.....I will say it too...Check your fuel pressure.....take your bottom back seat out...turn the ignition to the on position....u will hear the pump turn on.....if its making more than just a short few second hummm...or groan u might have an issue....if ur Fuel pressure is loooooooooooooooow....u could have dying pump
Old Aug 14, 2006 | 11:03 AM
seanish4042
yeah im gonna try to check the pump tonight...is there a voltage/resistance test i could use? im gonna borrow my boys and see what happens.
i dont have the necessary tools to check pressure...i dont think...
Old Aug 14, 2006 | 06:29 PM
seanish4042
well after two effing hours i couldnt get the goddam hoses off my friends fuel pump. jesus h christ how the hell are you supposed to get those things off? i tried every which goddam way and they didnt even budge.
so anyway, i got home, left the car running, took the back seat off and listened. almost silent. so i suppose that means its not the pump.
i did get a code for an O2 sensor last week, but i cleared it and it hasnt come back. if it was bad, wouldnt i be getting a code?
this is so goddam frustrating. i dont even know what to do next.
Old Aug 14, 2006 | 07:33 PM
Digitized's Avatar
I have that too.. O2 sensor changed, Fuel pump working...
some sya it's a grounding issue or the ignition switch..
I have yet to install both... I'll do the ignition switch first
and if that doesn't solve the issue.. then the grounding,
and if THAT doesn't solve the issue, then I have no clue...
Old Aug 15, 2006 | 07:47 AM
seanish4042
can someone give me a list of things to check since i DO NOT have the equipment to check pressure?
again...listened to the pump while the car was running...almost totally silent.
could it be the pressure regulator?
and as for getting the pressure checked...does that take a long time or could i just bring it somewhere and they could do it quickly.
also...i dont have the NGK spark plugs. the ones i got were like 2.50 each at pep boys.
like i said before...when i rev it up high, on the way back down at about 3000 i hear this smack. i havent been able to pinpoint it. i looked in the spark plug shaft in cylinders 2,4,6...and honestly i couldnt tell the difference. how can one tell whether spark plugs are working or not...
Old Aug 16, 2006 | 08:33 AM
HYTE's Avatar
Sounds like maybe you should check the cat. put your hand byu the muffler and see what kinda pressure you got. a clogged cat my throw 02 codes and would cause loss of power backfire and rough idle. give it a shot.
Old Aug 16, 2006 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
I pay 1.80 for my NGK's...
Spend 15$ for a haynes manual to check for FP.
Or 20$ on here to search.. or both...
http://forums.maxima.org/showthread.php?t=352052
http://forums.maxima.org/showthread.php?t=315429
Old Aug 17, 2006 | 07:22 AM
seanish4042
i do have an O2 code. 0503.
the exhaust smells liek burning rubber sorta. very rough, put-put sorta thing.
i dont have the 0702 code for a bad cat. could an oxygen sensor be the cause of this?
i think i read somewhere that the front heated oxygen sensors turn off after 3000rpms.
is it just a coincidence that my car runs a lot better after 3k?
Old Aug 21, 2006 | 07:27 AM
seanish4042
bump for that 3k question.
thing runs fine at WOT.
Old Aug 22, 2006 | 06:14 AM
NmexMAX's Avatar
dot dot dot ...
Change the 02 sensor and find out.
Old Aug 22, 2006 | 06:34 AM
Majestic's Avatar
Yahhhhhhh
I am somewhat having the same problem. I replaced my fuel pump with a cheap azz one from Advanced Auto Parts.
Old Aug 22, 2006 | 07:03 AM
seanish4042
im getting a used one most likely. alerady head it lined up.
i just need it for school this last year, then i will have a company car.
i cant imagine parting with my max tho. that is gonna be sad.
Old Aug 22, 2006 | 08:33 AM
seanish4042
well i just talked to the mechanic...and he said the lower o-ring on the injector i replaced was ripped to ****. i was like WTF.
so hopefully that will solve the problem of missing etc.
Old Aug 25, 2006 | 05:56 PM
seanish4042
just thought id update this...seeing as that the problem is fixed.
misfire...was caused by.....................
the lower motherfuking o ring on the new injector i installed. apparently it was like ripped to shreds, and was the cause of all my problems. ugh.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
