NOOBIES: The "I AM NEW HERE BUT HAVE A QUESTION" thread...
Old Oct 7, 2006 | 04:42 AM
  #201
FX45's Avatar
Originally Posted by KRRZ350
Jack up the car and make sure the wheels spin freely. Press and release brakes and make sure they still spin freely again. New brakes must be broken in, your supposed to go real easy on the first few stops, allowing them to cool each time while using them harder and harder. You did use disc brake grease right? Also, did you use brake cleaner to take the anti-corrosion treatment off of the new rotors? anyways, jack it up and let us know.
I'll go jack up the car right now to try that out. Disc brake grease uhhh not sure that you mean I use synthetic grease on the pins, very little and made sure they slide very easy. ANd then I used a special alcohol base cleaner on the rotors which took the anti-corrosion treatmeant off.
I followed this website STEP by STEP and did every thing it said.
http://www.motorvate.ca/mvp.php/300
http://www.motorvate.ca/mvp.php/301
http://www.motorvate.ca/mvp.php/302
Old Oct 7, 2006 | 05:25 AM
  #202
dgeesaman's Avatar
Maintenance Monster
It's entirely possible you smelled the brakes because they were still bedding in. If you hadn't just changed the fronts, I would have suggested you see if it's a rear caliper since the e-brake cable sometimes get damaged and don't fully release tension.
I would lift the front of the car and rotate the wheel. You should feel just a little bit of drag due to the pads and differential, but that's about it. With an LSD it may be a little more drag since you're turning more stuff inside the tranny.
Dave
Old Oct 7, 2006 | 05:49 AM
  #203
FX45's Avatar
Dave
ok thanks. I just lifted my car and spun the tires, they would only spin for like 3 or 4 inches after my hand stop pushing them. I then had my dad press the breaks while I spun them, and they stopped instantly, so I know they work. Roughly how many km's until the new break pads wear in? If it does continue to smell does that mean the pins are arn't loose enough? I'm pretty sure when I was doing the pins (cleaning them up and regreasing) that I made sure they slide extremely easy. thanks
Old Oct 7, 2006 | 05:55 AM
  #204
FX45's Avatar
another question too, I've been trying to search for threads about "brakes" and "fixing brakes" but I can't find a search button to search for it. Is there even one?
Old Oct 7, 2006 | 06:35 AM
  #205
nismology's Avatar
Originally Posted by nismology
When you put too much grease on the pins it creates a vacuum that draws the pin in and causes the brakes to drag more than normal.
It has nothing to do with the pins sliding freely or not. You CAN put too much grease. You should never smell brakes after a brake job unless bedding the pads in per this procedure (or similar)- http://www.zeckhausen.com/bedding_in_brakes.htm
Old Oct 7, 2006 | 07:04 AM
  #206
FX45's Avatar
cool thanks I just read all that, I'm going to try it. But then I found a linked part from that site to bleed my breaks. Also is it possible to replace the drum's on the back of my car or is that not possible for an amateur?
Old Oct 7, 2006 | 11:14 AM
  #207
Chromadesigner's Avatar
I need some help on my lower control arm bushings. My tire shop is to the point where they won't align my wheels until I replace the lower control arms on my I30 (96). I tried using the search feature, but it won't work. WHY??? The regulations on this sight seem a little overkill.
I've found a few sites that show replacement bushings without the entire arm. Are there anythings I should watch out for?
It's non-touring btw.
Old Oct 7, 2006 | 04:38 PM
  #208
Peter66's Avatar
Which Speakers?
ok I'm lookin to buy some front speakers for my 96 max, it has the stock 4 speaker set up - not bose. It has a panasonic cq c1300u deck. I'm not interested in a full set up, so I wont be looking to upgrade with an amp or a sub later on. My question is what would be the best speaker choice for around $100 (just front), although I'll pay more if something is a lot better. I'd like a little more bass, and sq, although I'm not expecting a whole lot.
Old Oct 8, 2006 | 01:31 AM
  #209
mastercater7's Avatar
VQ35 FTW
Exhaust?
cattman headers and straight pipe back? or cattman headers and greddy sp2?
Old Oct 8, 2006 | 07:02 PM
  #210
anovib's Avatar
I have a 98 gxe with 117k miles and recently there has been a roaring noise coming from the rear of my car when i hit 40 mph. It goes away when i go faster only to come back a lot louder at around 60mph. Please help me figure out what it is.
Old Oct 9, 2006 | 03:09 AM
  #211
dgeesaman's Avatar
Maintenance Monster
Rotate your tires front to back - if the noise moves with them, get them inspected or replaced.
Otherwise, it might be a wheel bearing.
Dave
Old Oct 9, 2006 | 03:11 AM
  #212
dgeesaman's Avatar
Maintenance Monster
Buy whatever fits and is on sale. When you're using a built-in amp and stock wiring, pretty much any decent speaker will be an improvement over stock, and they will all sound about the same. So I don't recommend spending any more than $60/pair since I don't think you gain anything.
Dave
Old Oct 9, 2006 | 10:23 AM
  #213
JPMax's Avatar
What's next!?..
It's much easier to just replace the whole LCA than try and replace the bushings which from what I hear requires burning out the old ones with a torch.
Old Oct 9, 2006 | 10:29 AM
  #214
JPMax's Avatar
What's next!?..
I've got the same HU! Love that mp3 capability.
I replaced my stock speakers with Pioneer 1780 4-way speakers. Very nice sound.
Old Oct 9, 2006 | 01:48 PM
  #215
dgeesaman's Avatar
Maintenance Monster
Yeah I went thru the whole urethane bushing installation. It's a bear to remove the old bushings unless you have a big torch and big tools to wrestle them. Although the suspension is tight again, it pops and creaks since I didn't tap in zerk fittings.
If I had to do it again I would never have screwed with changing those bushings - I would have bought new OEM arms and moved on with life. OEM bushings that aren't worn out work just as well as aftermarket urethane, but with a lot fewer hassles.
Dave
Old Oct 9, 2006 | 03:18 PM
  #216
Peter66's Avatar
ok I got another question, found some Eclipse SP8964 6.5" 2 way speakers, do these fit a 4th gen front?
Old Oct 9, 2006 | 03:26 PM
  #217
dgeesaman's Avatar
Maintenance Monster
Go to crutchfield.com and figure it out.
Dave
Old Oct 9, 2006 | 03:29 PM
  #218
Peter66's Avatar
Dave
thanks, yeah I already checked and they dont carry it
Old Oct 9, 2006 | 06:33 PM
  #219
dgeesaman's Avatar
Maintenance Monster
Well then eclipse should be able to tell you the mounted depth. Crutchfield should give you an idea how deep a mount it can allow.
Although I put 6.5's in my car and I needed crutchfields adapter plate. You can make one, but theirs was easy to use and sealed up nice and tight. Crutchfield may be overpriced on many things, but buying affordable car audio with the kits is ftw.
Old Oct 9, 2006 | 07:36 PM
  #220
Cdg2125's Avatar
Not sure what you mean by straight pipe back...the straight pipe is only replacing the cat. You still need a y, b, and muffler.....What are you talking about?
Old Oct 9, 2006 | 07:44 PM
  #221
ethnic6's Avatar
to make things simple just go cattman and greddy sp2
Old Oct 9, 2006 | 08:39 PM
  #222
VQ35 FTW
im saying like a straight pipe from my cat all the way into an outlet. no muffler
Old Oct 9, 2006 | 10:14 PM
  #223
Cdg2125's Avatar
No. You need a cat. to pass emissions for one. You wont gain anything from doing a straight pipe. Get the sp2 and a y.
Old Oct 9, 2006 | 10:25 PM
  #224
VQ35 FTW
ok thanks man. and do you know why it wont let me search? and where can i buy seafoam stuff?
Old Oct 9, 2006 | 10:35 PM
  #225
Cdg2125's Avatar
You cant search because you need to donate $20. You can get seafoam at any auto store. Make sure you check up on seafoam and you need to do an oil change afterward I believe.
Old Oct 9, 2006 | 10:39 PM
  #226
VQ35 FTW
how much does it cost? and you just pour it in your manifold?
Old Oct 10, 2006 | 06:20 AM
  #227
97maxigreen's Avatar
Hello everyone.. I am a new and I have been checking this site out and reading all this great info. I have read all the stickies and honestly, cut down down about 3/4 of my questions that I had before I came here. SO thank you. I will now change my own brakes and also switching to NGK hopefully this weekend. but I do have one question and I have searched for the answers and so far I was not able to find it..I really did look..I was wondering if you can help. My 97 Maxima has this strange knocking sound when the engine is running but as soon as I press on the clutch the noise goes away.Then the noise comes back when I take my foot off the clutch..Anyone please? Thank you
Old Oct 10, 2006 | 08:43 AM
  #228
dgeesaman's Avatar
Maintenance Monster
http://forums.maxima.org/showthread.php?t=486088
Old Oct 10, 2006 | 09:00 AM
  #229
JPMax's Avatar
What's next!?..
Reviews are mixed on Seafoam.
http://forums.maxima.org/showthread....hlight=Seafoam
Old Oct 10, 2006 | 09:20 AM
  #230
mikeh's Avatar
I have a question about door handles... I have a 95 max and the passenger rear door handle is broken... will the 96-99 door handles fit.. or are they year specific?
thanks
Old Oct 10, 2006 | 09:36 AM
  #231
mikeh's Avatar
do door handles differ from 95-99?
Old Oct 10, 2006 | 10:14 AM
  #232
JPMax's Avatar
What's next!?..
thanks
Inside or outside handles?
I think they're all the same except for the SE models having body color exterior handles and GXE/GLE models have chrome.
You should check the 4th Gen forsale section for people parting out their cars. Might find someone with the same color.
Old Oct 10, 2006 | 10:15 AM
  #233
mikeh's Avatar
its the outside... its maroon with the chrome handle.... so you think that all 4th gen are the same?
Old Oct 10, 2006 | 10:26 AM
  #234
phillydj's Avatar
New Question
Hi all , sorry If this has been asked, but im very pressed for time (my car is sitting on jackstands) recently i started a clutch job on my 1995 maxima and discovered that the clutch fork has a clip that holds it to the trans
that clip is broken , how important is it? also i have been looking for the fork everywhere here in philly and can't find it anywhere can anyone point me in the right direction for it?
Old Oct 10, 2006 | 10:44 AM
  #235
LILMAN's Avatar
New Question
I have a 96 GLE auto. When coming out of first gear I feel a heavy jerk going into second gear this only happens when going from first to second.What is it and how to fix it. TIA.
Old Oct 10, 2006 | 11:32 AM
  #236
JPMax's Avatar
What's next!?..
This is normal from 1st to 2nd gear. After a while you learn to take your foot off the gas a little at the right time so it slides into 2nd more smoothly.
Has the tranny fluid been flushed and replaced recently? It may help a bit.
Old Oct 10, 2006 | 12:14 PM
  #237
hey dgeesaman... thank you very much for you help.
Old Oct 10, 2006 | 12:28 PM
  #238
LILMAN's Avatar
I doubt it. I got the car from a shady dealership back in April. I've had to replace the whole front end suspension so far, so that should tell you the condition of the car. I'll try the tranny flush from the How to section.Good lookin out.
Old Oct 10, 2006 | 04:52 PM
  #239
dgeesaman's Avatar
Maintenance Monster
I'm a little surprised it's broken. Bent, yes, but I haven't seen one break yet.
Anyway, it's Nissan PN 30534-03E00. Order it from your dealer if someone local doesn't have a spare.
Dave
Old Oct 10, 2006 | 04:55 PM
  #240
phillydj's Avatar
Thanks for the info , I actually meant that the clip that holds it down is broken , not the fork. that was cut into by the pressure plate
when i order the fork does it come with the clip?
