To those with 235/17's...
Old Aug 21, 2006 | 07:46 AM
95bluse's Avatar
Do you guys feel the car "tramlining/tracking" quite a bit? Meaning the car wants to follow road imperfections quite a bit. I've done some major replacements to my front-end recently:
- LCA's
- end link bushings
- right inner-tie rod
- eiback/illumina/strut mounts/bearings (used) Illuminas set at 1 now after playing around with it
- alignment
Tire pressure is 35 front/34 rear. The car tracks very straight on the h/way with no vibration. Around town, it seems to tug left & right depending on the road. It did this before all the work was done. Seems it's worse when I switched from oem 15's to 17's, then again there was so much looseness before, I'm not sure if this is normal. I know that wider tires would cause more tracking when road ruts are encountered. I just expected it to be more apparent on the highway vs city streets.
Appreciate your input.
Old Aug 21, 2006 | 07:48 AM
MaximaSE96's Avatar
Maxima Owner
yes....wider tires will do that....especially if they are warn in the inner tread blocks
Old Aug 21, 2006 | 08:26 AM
95bluse's Avatar
I better check mine, the car was driven a few days before the alignment.
Old Aug 21, 2006 | 09:02 AM
nismos14's Avatar
§è~® f®ÈÄk
It's not the size that causes the tramlining, its the tire.
Old Aug 21, 2006 | 10:11 AM
95bluse's Avatar
Kumho Ecsta AST...H-rated I know,but I wanted something cheap/smooth ride (to offset the Eibachs) & quiet. The tires do all of this...except the wet traction is quite poor. Oh well...
KRMZN603
Sep 19, 2015 11:51 AM
NikeGal
Aug 7, 2002 06:11 PM
azn328i
Jan 8, 2002 06:41 AM
