My car sounds like an OLD CHEVY LUMINA :(
Old Aug 23, 2006 | 09:38 AM
ArcticW's Avatar
I guess the Y-pipe took a dump on me, 'cause now the ride sounds like a riced-out civic, or a really sh!tty GM v6 . How much is it to INSTALL a Y-pipe, I repeat ,INSTALL, not buy. I'm gonna buy a Warpspeed , so that just leaves me with the issue of how to get it on the car for cheap. DIY is not an option, don't have access to a lift
Old Aug 23, 2006 | 09:42 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
some jacks could do it also
Old Aug 23, 2006 | 09:45 AM
gx2nds4's Avatar
seeing as his car is a 95 there'll be lots of rust. They charged me 140 for mine which is pretty expensive. Before you order your y-pipe check if your cat is good. Mine was spot welded so i had to buy a new cat when i had my y-pipe installed
Old Aug 23, 2006 | 09:51 AM
ArcticW's Avatar
You would be correct. I was horrified when the car was last on the lift .
My cat seemed to be in functional if ugly shape then, but after 9 months, I don't know....
( Backround info: the exhaust seal broke last winter, the Cat and Y-pipe were completely separated cause the joint 'prolly rusted out, it was horrible, the car sounded like a school bus or diesel train, and with no $ and it being December, I just had the shop fix the seal.....)
Old Aug 23, 2006 | 09:53 AM
NmexMAX's Avatar
dot dot dot ...
You don't need a lift to do the y-pipe...Read the stickys for once in your life.
So in order to get this story straight... You have a y-pipe... but need an installer?
You will probably have better luck in your regional forums or calling around..
Truthfully, you could do it in the time it takes to find a price you like from your regional forums or making phone calls.
Should be in the neighborhood of 50-75$
Old Aug 23, 2006 | 10:46 AM
seanish4042
haha i drove about a mile with one of the oxygen sensors not installed in my y-pipe.
thing sounded like a 75' buick hoopty with no muffler. i laughed all the way to the shop.
Old Aug 23, 2006 | 02:47 PM
nguyen925's Avatar
good thing im still waiting on whether or not i should install one or not..
Old Aug 23, 2006 | 03:04 PM
hectorc's Avatar
Upper Midwest Wheel Whore
I got mine installed for $75 at a place called Dino's by 90 and Harlem
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
AT978
Aug 15, 2015 06:39 PM
MikesChevelle
Aug 9, 2015 11:50 AM
