Ignition coils or something else?
A couple of days I got a Front heated Oxygen Sensor code but I cleared it and never came back. The next day, I noticed that everytime I let go the accelerator, the rpm would drop to 900-1k. Everytime I brake, I get it to 500 rpm. After an hour later that day, I got a misfire on cylinder 2. I cleared that and now it seems fine, but still having the rpm problem. Everytime I hit the accelerator, it will go up to 2000-2100 rpm and then switch gears, but never passed 2100 rpm until I hit like 55 mph. I am not sure whether I should change the coils or whether it has something else to do with the above problem. Currently I am waiting to see whether that misfire comes up again or not.
Originally Posted by chamiz
I am feeling power loss today while driving. Still waiting for that code to come up.
It will not go above 3000 rpm while driving, but while on neutral, it can reach higher.
Pls i need some help!!!! Im running in freeway in 5th gear about 65mph and my engine is sounds like dying, so i put in 4th gear its desame my check engine lights,brake lights,seat belt turn on,i really want to be at home that time so everytime i put in nuetral my engine is die but still running then put in 4th gear my engine start again.When i exit the freeway in stop sign my engine die already so i try to turn of everything first then my engine start again.its been ok in 1st gear,2nd gear,and 3rd gear when i got home do any body know wat is wrong with my car.
EMAIL ME:airness_81@yahoo.com thanks!!
dude the same **** is happening to me but mine maxima is auto. It's like the car has a mind of its own, look i changed the coils, did absolutly nothing big waste of money, i changed a lot of stuff and it still runs like **** when it wants to. I mechanic came to my house and cleaned my EGR and it seems to be running fine now, you should try that or maybe its your MAF
Okay, checked the TPS and it's not giving a 5V reading when the key is turn to the ON position, but I am getting the 500 ohm to 4000 ohm resistance. The car is reacting good while on neutral with the accelerator pedal pushed down. Do you think I should still change the TPS? I will check the MAF next week on labor day weekend.
would any of these problems cause a 0505 code, my car 1995 maxima is ideling rough but seems to drive ok under throttle, but has defenite miss at idle, just started getin 0505 code what does that code really mean...No Faliure Recorder/Detected?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
