couple quick flywheel install questions
Old Aug 24, 2006 | 08:04 PM
acidspit86's Avatar
is there any wrong way to install it? i aligned the little hole on the crank and the little hole on the flywheel
is there any wrong way to install the timing ring?
Old Aug 24, 2006 | 08:20 PM
matty's Avatar
What Flywheel are you using ?? Remember to put the spacer in between the Flywheel and Bolts if your using the stock unit, keep it out if your using the Fidanza. Timing ring goes on the rear of the Flywheel via bolts. I think 8 bolts hold it on
A little Blue Locktight on the Flywheel bolts, and torque them down to 61-69 ft lbs and your set
-matt
Old Aug 25, 2006 | 08:17 AM
acidspit86's Avatar
fidanza... i was going to use a 5th gen clutch and pressure plate, but i called 4 dealerships that dont have it in stock. i knew i was taking a gamble on counting on them having it. so im going with a napa clutch, which they will have in a couple hours.... they saved my ***, i have to work at 5
Old Aug 25, 2006 | 10:25 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
uh, if a dealer doesnt have it in stock, they can order it for you and have it in a few days.
Old Aug 30, 2006 | 04:03 PM
Mxrider52's Avatar
I support for what?
Where do you guys find the flywheel torque at? I looked in the FSM and my haynes manual and cannot find it. Can anyone tell me the page it is on in the FSM?
Old Aug 30, 2006 | 06:17 PM
acidspit86's Avatar
the car had to run that day, i just didnt really plan ahead. i torqued the bolts to 75ft lbs
Old Aug 30, 2006 | 10:37 PM
Vlasic's Avatar
I just gun them on with my impact gun.............
Old Aug 31, 2006 | 04:46 AM
95mtlMAXSE's Avatar
shift_Puff
well, that can't be too good imo. An impact can go to 200 foot pounds if i'm not mistaken
JRod28
Dec 29, 2023 09:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 5, 2015 09:02 AM
