DAmn Parking LIght wont come out
im tryin to change the parking light can anyone help me?? i took the top screw out so i can wiggle it. but it seems like something on the bottom is holding it.. thanks in advance
hey, I've done this a few times. what you need to do is take out the top screw (obvi) then pull on the corner lamp until you can see where there is a small ball joint connecting the frame to the back of the lamp assembly. once you can see the joint, sneak a flat-head screwdriver in there between the ball and the joint and twist. You might have to pull a little on the lamp while you're twisting but I didn't need to. I hope this helps. Good luck.
- Jon
- Jon
YES!!!! YOU ARE AWESOME.. TOOK me less than a min compared to be4.. wiggiling it.. tuggin it.. banging it.. kicking it... then finally giving up.. thanks!! lets just hope the lights are WHITE enough.. its got this yellow thing to it now.. cant see it too good because its still day out.. but thankS!@!!!!!
"kicking it" - hahaha
no problem, glad I could help. About the yellowish tint... if you bought Sylvania bulbs.. they're not going to be the same exact color as the headlights but they're close.. IMO the offwhite bulbs look alot better than those nasty-*ss yellow ones.
sctludwig
Sep 1, 2022 01:32 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
