Antenna Problems...
Old Aug 25, 2006 | 12:56 PM
albo's Avatar
Antenna Problems...
I have looked at the stickies and seen how they lay it out for yea of the parts and all that... when i tried to fix my antena that does not want to go down, i was trying to unscrew the antenna nut and im having a hard time... any ideas of how i would be able to get that. unscrewed so i can try to figure out whats going on with the antena... like if theres a tool. or im just doing it wrong...
any ideas..?
thanks.
Old Aug 25, 2006 | 02:45 PM
'96 B-rad's Avatar
Are you sure the motors working?
Old Aug 25, 2006 | 05:39 PM
96i30azn's Avatar
i use 2 14 gauge bike spokes and an adjustable wrench
Old Aug 25, 2006 | 09:13 PM
I-30BLACKDEMON's Avatar
To replace the antenna there is the crome piece at the base of the antenna rod (out side, rear passenger quater panel). It has two grooves in it on opposite sides. Use a pair of needle nose pliers and turn counter clockwise. It will unscrew and come out. Next turn on your radio so that the antenna comes up. If it is not in to bad of condition you should be able to pull the rod and guide cable come out as it extends. Mine personally had so much corrosion in the motor and cable assembly that I replaced both motor and antenna rod together since it would not pull out. If yours does come out then all you need to do is start the new guide cable and rod into the slot and turn off your stereo to begin to retract the new unit. If it goes well then it will take the new unit down and all you have to do is reinstall the trim nut to hold everything in. Is not usually pretty hard unless your car is mine with corrosion down in the whole assembly. Damn the east coast!
Old Aug 28, 2006 | 09:46 AM
jjamzman's Avatar
I am on the east coast too. I wipe the mast with vaseline a few times a year and it seems to really help.
jjam
Old Aug 28, 2006 | 10:28 AM
albo's Avatar
alright. thanks.. the motor does work... it does the noise like its trying to pull the antenna up and down... so i know the motor. works.. i think its just the rode being a pain in the (yea all know what)... but il try to unscrew it.. becasue i so hate parking my car and having that antenna... up . because thats where its stuck.... but anyways il let yea know if it works... thks
Old Sep 7, 2006 | 04:56 PM
steph's Avatar
more antenna issues
I jut removed my 96 power antenna. There is only three wires so how hard can it be?????
The new unit does not work. The original wiring is a red wire (power I presume) a black wire (ground I presume) and a black wire with red stripe(signal from radio?). The new unit has a red wire, with fuse, a black wire and a blue wire. The minimal istructions indicate that the new unit wires are red for power, blue for radio "on" and black for ground. I reinstalled the old motor and it does drive properly. Any ideas? I guess it could be a defective unit from brand new but how likley is that?
Old Sep 7, 2006 | 05:26 PM
Allens96SE's Avatar
Hey, this worked for me.. Either be quick on your feet, or have a buddy in the drivers seat, to click the key back and forth making the antenna go up and down, and as it comes up, spray some WD-40 on the mast, or use some sort of lube. Then as it is going down, take your palm and push the mast down once it has stopped moving but you can still hear the motor trying to pull down.
You might have to do this a few times, and you definitely will have to GO EASY! Good Luck!!
Old Sep 7, 2006 | 09:44 PM
cslasher's Avatar
I just replaced mine. It's definetly a good idea to have some one to press the button for you. And like mentioned above, spraying WD-40 helps.
Old Sep 8, 2006 | 05:21 AM
Digitized's Avatar
in my 96, the original radio antenna broke in half and the antenna wouldn't go up /down anymore... the motor is still good as I can hear it spinning..
i purchased a replacement antenna, got the original out but was unable to get the 1/2 antenna left out of the unit..
I then purchased a used antenna/motor and put that in instead.. so good to have a working antenna again..
then for curiosity purposes, I opened up the old unt ( motor assembly) and saw the reason why the antenna wasn't going up or down is because the threaded plastic part of the antenna, snapped, therefore, the "gear" wasn't hooking the plsatic threaded part of the antenna...
if your antenna has no corrosion, I suggest replacement rod( antenna) which is approx $10.. if your antenna has corrosion and you are unable to get the mast/antenna out, I suggest finding a used but functionnal OEM antenna+motor unit.
Old Sep 9, 2006 | 08:31 AM
2DMax's Avatar
I find motor oil works better than WD-40....and Vaseline?!
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
