Up all nite in the rain doin my Suspension
like the title says i was up all night doin my suspension wit my boy. It is now 7:30am and we just got breakfast. But the whole night we were workin on it. from 1am to 6am. we did the front with LOTS of WORK. But the rear really did a number on us. WE took out the wheel and was tryin to take out the bottom screw that holds the strut. But the Nut is covered by some metal flange. And when i turn the screw to loosen, the screw and the nut moves at the same time. Not allowing me to loosen the screw. The area is too small to get a wrench to hold the nut in place. If only the metal flange wasnt there. We tried to rachet the bolt off but the nut spins along wit the bolt and the flange is covering the bolt. (DItto in a different way) Does anyone have this problem?? if do PLEASE help. my car looks rediculous with the front nice and lowered and the back just sticking up in the AIR... oh yea i have a 96max gle and installed or installing kyb struts/shocks with bomz springs. And one more thing, on the way back from the diner, we went powersliding in the rain, now the driver side makes a clunking noise whenever i turn, even when the car isnt moving and im just turning the steering wheel. anybody kno what that is???
maybe the metal thing around the rotors ?...it made a noise in mine ...u just push it back ...try that.
Wedge a screw driver between the nut and the cage. Give it a slight tap with a hammer so it's jammed in there holding the nut. Position it so the nut spins down onto the blade when you back the screw out. That will hold the nut in place so you can unscrew the bolt from it.
TIP: You don't need a spring compressor to do the rears. They are not under much preload at all. Take the top nut off and it will pop up about 2 inches. You can even put it back together with just somebody pushing down on the top while you catch the nut.
clunking or creaking? do you feel anything in the wheel when this happens?
What you're describing seems steering system related but I've had a clunking before after I abused the thing. Try kicking the wheel to see if you have an freeplay.
wow 6 hours ? i did mine tein gr2 setup in 3. and the other poster is right you dont need a compressor for the rears just push and twist the nut off. the front however will kill ya if you dont use a compressor, LOL...
like the title says i was up all night doin my suspension wit my boy.... ....when the car isnt moving and im just turning the steering wheel. anybody kno what that is???
this was a problem i faced.... apparantly when the shocks were replace before the person didnt put the right one back in so the nut and bold would turn togheter...
atleast you had a friend ... well i had a lift and shop but it took me from 9:30am to 6:30pm cause of that nut which relaly slowed it down..
but the satisfaction of doing it yourself is something that you can be proud of.
for the rears that flange is suppost hold the bolt in place so you can just use a 17mm socket and break the bolt free. But if it is spinnin the wedged screw driver technique should work.
WD-40 or equivalent can help, if not add some heat. Worse comes to worse, cut the bolt off and replace it.
heh i used the welder to heat up the nut.. then replaced it... great having shop access + parts store that delivers
I had the same problem... I welded the nut in place, You just have to be careful you do not get weld debris in side the nut on the threads. Also, getting in there with a Mig was also a little difficult, and had to redweld twice or three times, but eventually works. Time sounds right, I only had that happen on one side and it took me 3 hours to get it finished.
Originally Posted by HomerMAC
did you replace the nut with one that has enough depth so it locks into the clamp like metal piece that is on the axle..
yea i am goin to take it to my mechanic to tell him to weild it probably.. but cutting it off seems MUCH easier..still trying to picture it in my head.. what would happen after i cut the bolt... but damn that clunking noise is terrible.. everytime i turn theres a clunk.. now everytime i go thru a bump.. there is a Slight clunk.. i hope my wheel wont just fall off on me while im driving... another lesson i learned.. DONT go POWERSLIDING if u want ur car to last longer and dont wanna spend too much money on it..thanks guys.. im goin to post be4 and after pics after im done...btw.. the front looks SWEeT
Apr 16, 2020 05:15 AM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
