Braking Idle
Old Aug 29, 2006 | 11:03 AM
gassian's Avatar
Braking Idle
I have this problem and I am not sure exactly what it is.
My idle is perfect. It is at 750rpm.
WHen I drive and do full stop and my foot on brake it drops dops nicely to 500rpm.
Could this be a EGR problem?
Thanks in advance
Old Aug 29, 2006 | 11:55 AM
xlr8r's Avatar
Sounds like it's running perfectly. Any codes?
If it ain't broke.....
Old Aug 29, 2006 | 12:05 PM
gassian's Avatar
i have the EGR code even though i replaced the eg valve with new one abt 2 or 3 months ago.
Old Aug 29, 2006 | 12:22 PM
xlr8r's Avatar
that sux. Hate them emissions codes.
You're just going to have to go through the test sequence. Check the EGR valve, replace vacuum hoses, check electrical wiring/connectors.
I think the Haynes/Chiltern manual has some ways to test these parts.
Solenoids should click when you put 12V on them. Blowing/sucking the various ports should reveal if it's working. (jus don't suck too hard!)
Good luck, sounds like it's not hurting performance. You got a smog test coming up?
Old Aug 29, 2006 | 01:09 PM
gassian's Avatar
ohh no i just passed the smog by a hookup lol
okay i'll try to do those...sucks bowls ughh annoyin
Old Aug 29, 2006 | 05:34 PM
TunerMaxima3000's Avatar
750rpm is normal when you start the car initially, and after driving it should drop to about 550, unless you are running the fan or a/c, defrost, etc.
like he said, if it aint broke....
but I go by this rule, if the engine light is on, there is ALWAYS something wrong. LOL mine is still on i've fixed SOO much shyt its driving me nuts
Old Aug 29, 2006 | 05:48 PM
99se5speed's Avatar
SHIFT_up
Had the same problem. Clean you IACV!
Old Aug 30, 2006 | 09:34 AM
gassian's Avatar
okay i'll try to do that this weekend..thanks
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
