Brake Vibration
Old Aug 29, 2006 | 01:59 PM
svojs's Avatar
Brake Vibration
This morning I accelerated my Max up to 100mph then bigfoot the brake from the most inner lane to most outter lane to exit freeway. I experienced pretty serious vibration from brake while braking. I am sure It's NOT ABS working. Never experienced this before.
My brakes work very well under 90 mph with regular brake kick. Any explanation for such vibration?
Old Aug 29, 2006 | 02:02 PM
Dubbya's Avatar
VK56 Inside
Warped rotors?
Old Aug 29, 2006 | 02:05 PM
keb1209's Avatar
Originally Posted by Dubbya
Warped rotors?
I just went through the same thing a month or so ago... I replaced the rotors and pads and all was well again.
Old Aug 29, 2006 | 04:43 PM
adithius's Avatar
Sounds like warpage.
Old Aug 29, 2006 | 05:42 PM
maxprivate's Avatar
Black Lion
yup had the same problem get your rotors cut and new pads.
Old Aug 29, 2006 | 05:43 PM
TunerMaxima3000's Avatar
brake vibration is almost always a rotor issue, cant be much warp-age if you only experience it at those speeds, but definately something to check out.
Old Aug 29, 2006 | 06:02 PM
svojs's Avatar
Could be the rotor. My rotors are the original ones since day one. Now it's 93k already.
I got a report at 90k service mentioning that my brake pads are still 4-6mm thick. Looks like I can still use them for a while.
I will check the rotors when I need to replace brake pads (later).
Thanks, folks!!!
Old Aug 29, 2006 | 06:11 PM
This is just my honest opinion, but for the price of them and the % of common wear when the brake pads are done, always replace the rotors at the same time, if you replace only the pads you will get vibration and your pads will not last as long, just what I know, do what you please.
Old Aug 30, 2006 | 08:30 AM
nikk1973's Avatar
i have that similar prob....i had the the dealers to chek the alignment and bal. the tire ...that didn.t help....now they say its the rack oppionion it was weak...my break and rotor are fine ...but it gives me a bad vibration at 65 to 85 ...have not reach 86 and up scared...lol car might fall apart from the vibration...any suggestion.......???????thankxxx
Old Aug 30, 2006 | 08:46 AM
Dubbya's Avatar
VK56 Inside
Could be a balljoint issue.
Old Aug 30, 2006 | 08:53 AM
the_3d_man's Avatar
Can you turn your steering wheel before the actuall wheels start to turn? if so there is play in your steering. Could just be tie rod ends... anyway... it's rack and pinion (as in rack and pinion gears). Sounds like he's trying to impress you with words that he knows you've never heard of.
Old Sep 16, 2023 | 10:01 PM
I35GEEK's Avatar
If you do the work yourself, rotors are cheap. Try replacing the front rotors first if you feel pulsation from your brake paddle when braking. See if pulsation goes away before also doing the rears.
Old Sep 17, 2023 | 02:14 AM
Rit's Avatar
Rit
I hope it has already been fixed in the last 17 years.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
