Need help: need to remove 98 bose deck
Old Aug 29, 2006 | 02:05 PM
Noslen's Avatar
Need help guys,
tryin to get behind the bose deck, but i don't wanna break the trim. What do i have to do to take the deck out???
Thanks,
N
Old Aug 29, 2006 | 02:09 PM
Dubbya's Avatar
VK56 Inside
Pry out the center A/C vent/clock assembly in the dash. Pry out the Shifter Trim. Remove the ashtray. Once all of that is done you will see 4 screws that hold the metal brackets that the H/U and DIN Pockets are all mounted to.
Old Aug 29, 2006 | 02:12 PM
Noslen's Avatar
where do u start prying, i don't wanna break the trim. what did u use to pry it? butter knife?
Old Aug 29, 2006 | 02:23 PM
Dubbya's Avatar
VK56 Inside
I used the thinnest flat blade screw driver I could find for the A/C Vent Assembly. Start on the side of the A/C Vent Area using the dash board as the leverage point. As for the shifter trim just use your fingers. Grab it at one of the corners furthest away from the dash. You will need to grab the trim on the part that is cut out for the shifter. Then just pull up.
Old Aug 29, 2006 | 02:42 PM
Noslen's Avatar
thanks guys, i got it open.
now, do u guys know where i can get a wiring diagram? for the 98
Old Aug 29, 2006 | 02:44 PM
Dubbya's Avatar
VK56 Inside
I just posted the non bose one a few threads down. I already did my good deed for the day
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
