power steering resovior
Old Aug 29, 2006 | 03:03 PM
randy021186's Avatar
when the engine get hot....is the power sterring resevoir supose to bubble?
Old Aug 29, 2006 | 03:13 PM
csb's Avatar
csb
I believe it's normal. I've had many Nissans (and other manufacturers), and they all exhibited that very same behavior.
Old Aug 29, 2006 | 04:31 PM
nitink's Avatar
bubble means there is air inside. I don't think its normal, is your streering system leaking or something
Old Aug 30, 2006 | 09:21 AM
theres no leaking....i am getting kinda worried because this never happened before Is the tranny fluid and the powersterring fluid the same?
Old Aug 30, 2006 | 09:24 AM
it not like bubbling but like water flowing very quickly and u can see the water gushing up
Old Aug 30, 2006 | 01:41 PM
RA030726's Avatar
I'm nutty for Nissans
its supposed to move, the fluid is circulatimg through the system.
Old Aug 30, 2006 | 06:19 PM
DennisMik's Avatar
Nissan uses Dexron type automatic trans fluid in the power steering.
Old Aug 30, 2006 | 06:26 PM
csb's Avatar
csb
My p.s. system did this b4 my 3.5 swap and it does the same thing now (the system has been completely flushed as well). This, combined with the fact that all other Nissans I've owned exhibited this behavior, still leads me to say that it's perfectly normal.
Old Aug 30, 2006 | 06:35 PM
matty's Avatar
It bubbles when the a/c is on. Mine doesnt bubble under normal use
-matt
Old Aug 31, 2006 | 08:45 AM
asianbandit's Avatar
Good question
Mine bubbles...i believe it is normal? Could be wrong...
Old Aug 31, 2006 | 06:56 PM
Bleeding the Hydraulic sytem
NO its not normal.....i just fixed my problem....i have the official FSM
and it get worse with the ac on and another way to know the problem is when the hood is open (engine on) have someone turn the wheel u can hear a clicking noise sometimes its bad sometimes its good!
How to fix (it would be help full to have someone turning the wheel for you!)
1. suspend both front wheels in the air - engine off
turn left until u hit the stopper then
turn right until u hit the stopper
2.countinue until the resivior fluid stop decreasing and increasing
3.start engine and repeat step 2!
and there you will not see the powersteering fluid bubble or a heavy circulation flow...
lowpost99
Oct 26, 2025 06:53 PM
Fbana41
Aug 29, 2016 12:18 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
