Do I have a fuel pump problem?
Old Aug 30, 2006 | 12:30 PM
Digitized's Avatar
I have starting issues ( specially when the car is sitting for a few hours)..
Starter speed is normal
I changed the ignition switch...
I did a test this morning, I have 1/8 of gas left... I turned the key left it on accessory for 2 minutes and then I have almost 1/4 tank of gas..
now is this a sign of a faulty fuel pump and this is what is contributing to my starting issue? reason why I ask is when I start the car, when I press the gas( pump the pedal) it helps the car "catch" for startup...
so I changed the ECTS, grounded the engine and tranny and etc... changed the ignition switch... the only think left I can think of is the Fuel pump...
anyone have an idea?
thanks
KL
Old Aug 30, 2006 | 01:24 PM
svetlin55's Avatar
check =spark plugs,O2 sensors,crankshaft sensors-pef & pos,camshaft sensor.use injector cleaner.
Old Aug 30, 2006 | 01:28 PM
kcryan's Avatar
Check (with a spark plug tester) for spark, check for fuel with your nose, if one doesnt exist, theres your problem, also check codes.
Old Aug 30, 2006 | 01:59 PM
gassian's Avatar
I have the same issue too and thats what the dealer said that it might be the fuel pump..I grounded the engine, the tranny and also the starter too.
I have brand new injectors, cleaned the throttle, new starter, new egr valve.
Iam runnin out of ideas as well..
Old Aug 30, 2006 | 02:29 PM
Digitized's Avatar
The nissan dealer quoted me $262.00 for a brand new fuel pump.. gawd damn that's expensive!
Old Aug 30, 2006 | 02:35 PM
gassian's Avatar
same here it was about 271 they told me i think...yea freakin exp..but Warlbro pumps its cheaper
BkGreen97
Apr 2, 2016 05:47 AM
RWCreative
Sep 21, 2015 11:01 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
