Caliper Alternatives W/out Modification/Retrofit...?
Old Sep 2, 2006 | 11:37 AM
cam_honestiam's Avatar
I apologize if this has been discussed somewhere else; I could not find an answer to this question.
I have seen several people discuss alternatives to the stock calipers such as Q45, 300ZX, etc.
My questions is which alternatives from other cars will fit our stock setup without any further modification (in other words, straight bolt-on equipment)?
Help is appreciated.
Old Sep 2, 2006 | 11:40 AM
NmexMAX's Avatar
dot dot dot ...
Even if the caliper did fit, the rotors on these cars are a tad on the pansy side, so in order to fit a larger rotor, the caliper needs to sit furhter out regardless, hence requiring caliper mounting modification/reconfiguration.
Old Sep 2, 2006 | 01:54 PM
oldngivout's Avatar
Willing to learn
The stock front calipers & rotors from a 2004 Max will fit with only having to drill out the two mounting holes in the torque member. They are 12mm on the 95-99 and must be enlarged to 14mm. Stock brake lines will bolt right up, and no other modification is necessary.
Oh yeah, you will need at leat 17" wheels with spoke clearance to run these. Trial and error on the spokes is the only way to determine which wheels will fit.
Old Sep 2, 2006 | 03:48 PM
Cdg2125's Avatar
Everything needs to be modded to fit the car. But as was just posted the 6th gen setup fits easiest. Good stopping power without spending a $hitload for the actual bbk.
Old Sep 2, 2006 | 04:12 PM
NmexMAX's Avatar
dot dot dot ...
But the wheels must be changed so.... But that would be the kit I would go with IMO, best bacg for the buck if you already have wheels.
Old Sep 4, 2006 | 09:59 AM
So what about the Q45 calipers? I have heard talk about those. What modifications are necessary for those?
Old Sep 4, 2006 | 04:27 PM
Cdg2125's Avatar
bigger wheels, new brakets and hardware, new rotors...much more than the 6th gen
Old Sep 4, 2006 | 04:32 PM
99se5speed's Avatar
SHIFT_up
I believe that the J30 calipers w/ 2 piston's will fit without modification. I was speaking with ViperVadim about this just the other day. From what i understood you can use those calipers, OE brembo blank rotors for a maxima, and get the SS brakes lines and also get a 300z master brake cylinder and everything bolts right up and would work with the stock 16 SE wheels. The only thing he said was that you would need to bend the lines for the bigger master cylinder. Otherwise everything should still work fine with the stock.
He also mentioned something about the rotors being a little to small and you would need bigger one's and then cut them down a little to get the proper specs...I'm not to sure what he ment about this.
Old Sep 4, 2006 | 08:19 PM
krismax's Avatar
Father of the 00 VI
sentra spec v 4 piston brembos bolt on 100% i have a pair but iam selling them because i need a bigger rim than what i have to make it work.
you would also have to use the new altima rotor 11.7x24mm for these, stock dia at 11 is to small , i found a place that sells the rotors for $40 a piece.
Old Sep 4, 2006 | 08:23 PM
NmexMAX's Avatar
dot dot dot ...
Would A33B rotors fit?.. IIRC they are in that neighborhood size.
Old Sep 4, 2006 | 08:25 PM
krismax's Avatar
Father of the 00 VI
are they bigger than 11 inch and 24 mm wide?
these also line up perfect with stock 4th gen rotor but rotor is to small
Old Sep 4, 2006 | 08:56 PM
NmexMAX's Avatar
dot dot dot ...
A33B rotors = 11.68" X 24mm
Old Sep 4, 2006 | 11:20 PM
krismax's Avatar
Father of the 00 VI
perfect the calipers are made for 12.0 inch but 11.7 with a .15 radius diff isnt much to worry about...so with these calipers and the a33b rotors its a bolt on and the lines i have on my car work with no mods
Old Sep 5, 2006 | 06:44 AM
ardika's Avatar
I thought the drilling part is required for the two mounting holes for the torque member ON the spindle side. No further drilling required for the torque member itself.
Someone correct me if I am wrong.
Old Sep 5, 2006 | 09:10 AM
NmexMAX's Avatar
dot dot dot ...
That's exactly what he said.. is there an echo. or
Old Sep 5, 2006 | 08:05 PM
OK.
In order to avoid confusion, then, you are saying that the Sentra Spec V caliper will bolt on with no modification, but a larger rotor is required. The Altima or A33b will work in this case.
Is that correct?
Are you also saying that the stock rim is too small?
Old Sep 5, 2006 | 08:08 PM
NmexMAX's Avatar
dot dot dot ...
OK.
Is that correct?
That's exaclty what he stated.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
