Rear wheel bearing(s)... DIY?
Old Sep 3, 2006 | 06:31 AM
d00df00d's Avatar
Old enuf to pick his own gears
Is this something I can do myself? The FSM is really thin on details.
Old Sep 3, 2006 | 06:34 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I would should a PM to tavarish, from what he tells me it can be DIY, although it is a rather involved endeavor...are you certain that the bearings are shot, though?
Old Sep 3, 2006 | 06:41 AM
SMX95's Avatar
Borat is the fuken man! Do yew liek? My sister is a prosistue.
LOL!!! Sorry for whoring up the thread. That avatar that metal has is awesome
+100
Old Sep 3, 2006 | 06:45 AM
d00df00d's Avatar
No, I'm not entirely sure. I've just been getting a really strange groaning noise at times, and it occasionally resonates in the cabin. My tranny seems fine, axles wouldn't cause that kind of noise, and it doesn't sound like my one front wheel bearing did when it went on me a couple of months ago. If it does turn out to be a rear wheel bearing (or both of them), I just want to make sure I know what I'm getting into.
Old Sep 3, 2006 | 06:47 AM
nismology's Avatar
Your rear calipers might be seizing. Make sure it's not those first.
Old Sep 3, 2006 | 06:51 AM
d00df00d's Avatar
Oh yikes. Good call.
Old Sep 9, 2006 | 05:55 PM
AussieA32's Avatar
Just jack the car up and rotate the hub if you feel any resistance from the centre you will feel it. If the caliper is seizing you will feel the caliper grab the hub when you step off the brakes. So that will be a 2 person job. Get the other person to step on and off the brake or just pull on and release the park brake.
Old Sep 9, 2006 | 06:46 PM
jasonv's Avatar
or your rear shoes
Old Sep 9, 2006 | 08:44 PM
Sounbwoy's Avatar
Check the wear patterns on your tires while you're at it. If you have feathering, that could create the noise as well. I got a constant groaning noise as soon as I put my 17's on (used tires).
Old Sep 11, 2006 | 04:11 PM
nismology's Avatar
Originally Posted by jasonv
or your rear shoes
All A32 maxima's have rear disk brakes standard.
Old Sep 11, 2006 | 05:20 PM
funkynx2k's Avatar
rear wheel bearings are easy. They sell the whole hub assembly from nissan. It's kind of pricey (over 100 bux) but the bearings can't be replaced by themselves. But like I said, it's easy.
That being said... You probably do have caliper dragging. I had the same thing happen the wifes Maxi. I thought it was the bearing, had all the signs. Ordered it and replaced, but still made the noise. I took the caliper apart and regreased it and that fixed it. Now the other side is doing the same thing...
Good luck...
Old Sep 12, 2006 | 06:16 PM
jasonv's Avatar
are they ebrake on caliper or shoes in disc?
Old Sep 12, 2006 | 06:27 PM
MaximaSE96's Avatar
Maxima Owner
ebrake on calipers............a good way to check for wheel bearing is turn the wheel while holding the spring...if u feel excessive vibration its a wheel bearing
Old Sep 13, 2006 | 06:48 PM
jasonv's Avatar
or shake your wheel up and down or side to side. if the bearing is bad enough youll get some play.
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
